Cisco IP Phone 7900 series Mounting and Enclosures
Adam Stauffer
Anyone know of any ruggedized enclosures for mounting a Cisco 7900 series phone in a harsh environment?
Rob Huffman
Hey Adam,
Have a look at this "cool" IP Phone built for harsh environments (it may be cheaper/easier to use than an enclosure);
From Cisco partner;
Coleman Technologies, Inc. - EnviroXtreme
7961G/62G EnviroXtreme
http://www.ctiusa.com/PDF/EnviroXtremePhone.pdf
Hope this helps!
Rob
Wow, that is a serious phone. Have you used it or known any one that had? Thanks for the reply.
What information do you need to know about the phone?
If you have specific concerns or requirements I can put you in contact with the group within CTI that developed the phones.
Just more of a curiousity about anyones experience with the phone. I am sure it has the same features as the standard 79xx series.
I have an outdoor application where they are wanting a cisco phone but it would be exposed to the elements. I has hoping that someone made an enclosure where you could open it to gain access to a standard 79xx series phone. Thanks.
