Cisco IP Phone 7912 light indicators continuous on
Hi folks,
When powering up ip phone 7912 through inline or adaptor the light indicators continuously on and screen is blank.
MAR
Super Bronze
Re: Cisco IP Phone 7912 light indicators continuous on
Try doing a factory reset, but it sounds like your handset is DOA and will need sending back...:
HOld down # as you apply power to the phone, and continue holding it until the MWI light stays on.
Then press 123456789*0#
The phone should reset and try to download firmware again (make sure it's attached to the network with a working TFTP server for this).
If that doesn't work, send it back.
Please rate helpful posts...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron
I have checked it several times but it didn't work but any way thanks
MAR
Silver
I had a problem when upgrading to 4.1.3. It seems when you had a custom background image on the 7912 things went a little haywire and exhibiting something similar to what you have.
Just a thought. The TAC should help you find the bug ID.
Hall of Fame Super Gold
Don't send the phone back yet.
Connect to network with a DHCP server, and check that is it making a DHCP request. Make sure you are giving both option 66 and 150 as TFTP address in the DHCP reply.
Then observe TFTP request and give the phone any file it is requesting.
659
