Cisco IP Phone 7942 intermidately restarting
We done below task for afrosaid problem
1. Change the IP phone
2. Change the cabling from end user till switch port
3. Change the Switch port
4. Remove configration from CUCM for End user and Phone
But still problem is persisting ... Please assist me
Aman Soi
Hi Sandeep,
What is CUCM version and IP phone firmware?
IS phone working on PoE or Power CUBE?Are u facing problem with this phone model only?
regds,
aman
Aman Soi
Hi Sandeep,
regds,
aman
CUCM version - 8.1
IP Phone version SIP42.9-0-2SR1S
Phone is working on POE and this only 1 phone having such issue.
Sandy
Hi Sandeep,
Try doing factory reset of the phone ,
http://www.wikihow.com/Reset-a-Cisco-CP-7940G-Phone-to-Factory-Default
Are other phones working fine on the same switch where 7942 is creating problem.
regds,
aman
Check event-viewer logs. Collect from RTMT for the time issue happens. Keep a buffer of 10 min before and after the reboot happens
Tapan
