Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco IP Phone 7942 License
I want to know part number for ordering CUCM licenses for 7942 IP Phone.
Is this part number correct SW-CCM-UL-7942= ??
Thanks.
Shakir
Silver
Please give us CUCM version
Please give us CUCM version info.
BR,
Dragan
HTH, Dragan
Hi,Thanks for the reply, CUCM
Thanks for the reply, CUCM is v8.6. Kindly provide part number for both 8.6 and 9.0 pls.
Thanks.
I think it would be best if
I think it would be best if you reached out to the Licensing team at Cisco TAC. Since you are on 8.6, they would request your PAK ID, your server MAC address, and issue licenses to you for that MAC address, which can then be uploaded on the server.
You can go here : https://tools.cisco.com/SWIFT/LicensingUI/Quickstart
I've seen some SNs like the following:
L-CM-DL-5000=
L-CM-DL-100=
Here's an example.
http://www.posglobal.com/L-CM-DL-100=.html
Silver
In CCW go with this top level
In CCW go with this top level part numbers:
- CM 9/10 -
R-UCL-UCM-LIC-K9
Top Level SKU For 9.x/10.x User License - eDelivery
- CM 8 - if adding to existing CM then
L-CUCM-USR-LIC-ADD
Top Level Sku For Adding User License,
and if new installation then
R-CUCM-USR-LIC
Top Level Sku For User License.
7942 requieres Enhanced type of license so when you select anything from above just pick 1 Enhanced user license and that's all you need for this phone to be licensed...
HTH,
Dragan
HTH, Dragan
This is an exisiting setup
This is an exisiting setup.
Let me get full information from the customer and contact you guys.
Btw, these licenses are RTU only? which means I can configure and use these phones without purchasing the licenses but this will be illegal.? Correct me if I am wrong.
Thanks .
Silver
So you are going with add
So you are going with add option...these are not RTU licenses and they are required for your setup to work properly and legal...if you have existing DLUs on system then you maybe already have enough licenses for this - check that on licensing panel on CM.
You don't have RTU option when speaking on CM environments - RTU is something related to CME system.
BR,
Dragan
HTH, Dragan
Hi Shakir,If you have a CUCM
Hi Shakir,
If you have a CUCM version < 9.0, you will need to buy DLUs. The 7942 consumes 4 DLUs per device. So based on the number of devices you are adding you'll need to multiply 4.
If you are using CUCM version 9.1 (which has a much better licensing scheme than 9.0), then you will need to purchase either CUWL or Enhanced/Enhanced Plus UCL licenses
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-communications-licensing/product_solution_overview0900aecd806cc7a4.pdf
Hantale
Sree
Silver
Version 8 is also UCL based..
Version 8 is also UCL based...in fact that same UCL licenses are in background converted to DLUs wink
So it's important to find correct version of CUCM...
HTH,
Dragan
HTH, Dragan
Ah thanks for that info :)
Hantale
Sree
811
作成コンテンツを作成するには してください
