Cisco IP phone 7942 support in CCM 4.2(3)
Hello everyone,
I  have a client that is running CCM 4.2(3) (don't ask  me why) and they  would like to register a few 7942 IP phones. I read in  some other  threads that it would require running the following patch:
ciscocm.4-2-3-sr2b
I  ran the installation, but the log seems to show 2  errors, which is  probably why I still cannot see 7942 on the list. The  following is the  output of the log file (I've emboldened the text that  displays the  errors):
11:29:28:  Dumping current process list to "C:\Program  Files\Common  Files\Cisco\Logs\CCMPatch\Cisco Unified CallManager  4.2(3)sr2b  Installation 2011-11-21 11.29.log.Process List.log"
11:29:29: ********************************************************************************************************
11:29:29: ***********************************                               **************************************
11:29:29: ***********************************         Start of Log          **************************************
11:29:29: [Install of Cisco Unified CallManager 4.2(3)sr2b]
11:29:29: Installer Version: 3.60.06
11:29:29: Build ID: 0022010
11:29:29: Install Date: 2011-11-21
11:29:29: Install Time: 11:29:29
11:29:29: File Backup Location: C:\esbackout
11:29:29: Patch Backout Command: Add/Remove Programs: Cisco Unified CallManager - 4.2(3)sr2b Uninstall
11:29:29:
11:29:29: Pre-Install Database Check Started *********************
11:29:32: Initial Database access successful:  11:29:32
11:29:32: ****************************************************
11:29:32: Replication Status is At least one agent-implementing job has failed to execute successfully
11:29:32: Replication Initialization Begun ****************
11:33:38: Replication Initialization Successful ****************
11:33:38: Replication Status is At least one agent-implementing job has failed to execute successfully
11:33:38: GH ServerName: 172.20.11.10
11:33:38: GH Database: CCM0300
11:33:38: Local ServerName: CCM1
11:33:38: Local ServerIP: 172.20.11.10
11:33:38: Local ServerDB: CCM0300
11:33:38: NodeName: 172.20.11.10
11:33:38: CCM1 is a Publisher
11:33:38: DBConnection0 entry is Good
11:33:38: Pre-Upgrade Database Check Successful*****
11:33:38
11:33:38: ********************************************************************************************************
11:33:38: OS Revision Levels:
11:33:38: OS Image - 2000.4.3a
11:33:38: OS Upgrade -
11:33:38: OS Patch -
11:33:38: SQL Revision Level: 8.00.2039               excludes hotfixes
11:35:26: Embedded Device Package reported an error *****
11:35:26
11:35:26: Copying FileInUse replacement utility
2011-11-21 11:35:26 :
2011-11-21 11:35:26 : Stopping all COM+ Objects
2011-11-21 11:35:26 : Stopping All COM+ Components
2011-11-21 11:35:29 : Shutting down IIS-{Default Web Site//Root/CCN}
2011-11-21 11:35:29 : Shutdown complete for IIS-{Default Web Site//Root/CCN}
2011-11-21 11:35:29 : Shutting down IIS-{Default Web Site//Root/CCMCIP}
2011-11-21 11:35:29 : Shutdown complete for IIS-{Default Web Site//Root/CCMCIP}
2011-11-21 11:35:29 : Shutting down DBL
2011-11-21 11:35:30 : Shutdown complete for DBL
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/tftp}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/tftp}
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/CCMAdmin}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/CCMAdmin}
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/CCMServiceTraceCollectionTool}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/CCMServiceTraceCollectionTool}
2011-11-21 11:35:30 : Shutting down COM+ Utilities
2011-11-21 11:35:30 : Shutdown complete for COM+ Utilities
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/CCMPluginsClient}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/CCMPluginsClient}
2011-11-21 11:35:30 : Shutting down COM+ QC Dead Letter Queue Listener
2011-11-21 11:35:30 : Shutdown complete for COM+ QC Dead Letter Queue Listener
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/CCMPluginsServer}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/CCMPluginsServer}
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/PktCap}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/PktCap}
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/CiscoTomcatSecure}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/CiscoTomcatSecure}
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/CCMUser}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/CCMUser}
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/CCMApi}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/CCMApi}
2011-11-21 11:35:30 : Shutting down .NET Utilities
2011-11-21 11:35:30 : Shutdown complete for .NET Utilities
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/CCMTraceAnalysis}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/CCMTraceAnalysis}
2011-11-21 11:35:30 : Shutting down IIS Utilities
2011-11-21 11:35:30 : Shutdown complete for IIS Utilities
2011-11-21 11:35:30 : Shutting down IIS In-Process Applications
2011-11-21 11:35:30 : Shutdown complete for IIS In-Process Applications
2011-11-21 11:35:30 : Shutting down IIS Out-Of-Process Pooled Applications
2011-11-21 11:35:30 : Shutdown complete for IIS Out-Of-Process Pooled Applications
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/CCMPD}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/CCMPD}
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//root/BatFiles}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//root/BatFiles}
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/BARS}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/BARS}
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//Root/TraceTool}
2011-11-21 11:35:30 : Shutdown complete for IIS-{Default Web Site//Root/TraceTool}
2011-11-21 11:35:30 : Shutting down IIS-{Default Web Site//root/art}
2011-11-21 11:35:31 : Shutdown complete for IIS-{Default Web Site//root/art}
2011-11-21 11:35:31 : Shutting down IIS-{Default Web Site//Root/RTMTReports}
2011-11-21 11:35:31 : Shutdown complete for IIS-{Default Web Site//Root/RTMTReports}
2011-11-21 11:35:31 : Shutting down IIS-{Default Web Site//Root/CiscoTomcat}
2011-11-21 11:35:31 : Shutdown complete for IIS-{Default Web Site//Root/CiscoTomcat}
2011-11-21 11:35:31 : Shutting down IIS-{Default Web Site//root/BAT}
2011-11-21 11:35:31 : Shutdown complete for IIS-{Default Web Site//root/BAT}
2011-11-21 11:35:31 : Shutting down IIS-{Default Web Site//Root/Soap}
2011-11-21 11:35:31 : Shutdown complete for IIS-{Default Web Site//Root/Soap}
2011-11-21 11:35:31 : Shutting down IIS-{Default Web Site//Root/CCMService}
2011-11-21 11:35:31 : Shutdown complete for IIS-{Default Web Site//Root/CCMService}
2011-11-21 11:35:31 : Shutting down IIS-{Default Web Site//Root/ccn/GW}
2011-11-21 11:35:31 : Shutdown complete for IIS-{Default Web Site//Root/ccn/GW}
2011-11-21 11:35:31 : Shutting down BARS
2011-11-21 11:35:31 : Shutdown complete for BARS
2011-11-21 11:35:31 : COM+ Components shut down, exiting
2011-11-21 11:35:31 : iexplore.exe Process is being ended if detected
2011-11-21 11:35:31 : mmc.exe Process is being ended if detected
2011-11-21 11:35:31 : sqlmangr.exe Process is being ended if detected
process #5152 [sqlmangr.exe] killed
2011-11-21 11:35:32 : : Stopping DCDirectory
DCDirectory - stopping.
DCDirectory - stopped.
2011-11-21 11:35:37 : :  OK - Service Stopped Normally
2011-11-21 11:35:37 : : Stopping SacNTService
OpenService() failed:
    error code = 1060
    message    = The specified service does not exist as an installed service.
2011-11-21 11:35:37 : :  OK - Service is not installed on this server
2011-11-21 11:35:37 : : Stopping CiscoSNMPDataCollector
    error code = 1060
2011-11-21 11:35:37 : : Stopping Cisco RIS Data Collector
Cisco RIS Data Collector - stopping.
Cisco RIS Data Collector - stopped.
2011-11-21 11:35:47 : :  OK - Service Stopped Normally
2011-11-21 11:35:47 : : Stopping Cisco TcdSrv
    error code = 1060
2011-11-21 11:35:48 : :  OK - Service is not installed on this server
2011-11-21 11:35:48 : : Stopping Cisco Telephony Call Dispatcher
Cisco Telephony Call Dispatcher - stopping.
Cisco Telephony Call Dispatcher - stopped.
2011-11-21 11:35:48 : :  OK - Service Stopped Normally
2011-11-21 11:35:48 : : Stopping Cisco CTIManager
Cisco CTIManager - stopping.
Cisco CTIManager - stopped.
2011-11-21 11:35:53 : :  OK - Service Stopped Normally
2011-11-21 11:35:53 : : Stopping Cisco IP Voice Media Streaming App
Cisco IP Voice Media Streaming App - stopping.
Cisco IP Voice Media Streaming App - stopped.
2011-11-21 11:35:58 : :  OK - Service Stopped Normally
2011-11-21 11:35:58 : : Stopping CiscoMessagingInterface
    error code = 1060
2011-11-21 11:35:59 : :  OK - Service is not installed on this server
2011-11-21 11:35:59 : : Stopping Cisco Messaging Interface
Cisco Messaging Interface - stopping.
Cisco Messaging Interface - stopped.
2011-11-21 11:36:04 : :  OK - Service Stopped Normally
2011-11-21 11:36:04 : : Stopping Cisco MOH Audio Translator
Cisco MOH Audio Translator - stopping.
Cisco MOH Audio Translator - stopped.
2011-11-21 11:36:09 : :  OK - Service Stopped Normally
2011-11-21 11:36:09 : : Stopping CiscoUserLogoutSvc
    error code = 1060
2011-11-21 11:36:09 : :  OK - Service is not installed on this server
2011-11-21 11:36:09 : : Stopping InsertCDR
InsertCDR - stopping.
InsertCDR - stopped.
2011-11-21 11:36:14 : :  OK - Service Stopped Normally
2011-11-21 11:36:14 : : Stopping Cisco Tftp
Cisco Tftp - stopping.
Cisco Tftp - stopped.
2011-11-21 11:36:20 : :  OK - Service Stopped Normally
2011-11-21 11:36:20 : : Stopping Cisco Call Back
    error code = 1060
2011-11-21 11:36:20 : :  OK - Service is not installed on this server
2011-11-21 11:36:20 : : Stopping Cisco Extended Functions
Cisco Extended Functions - stopping.
Cisco Extended Functions - stopped.
2011-11-21 11:37:02 : :  OK - Service Stopped Normally
2011-11-21 11:37:02 : : Stopping CiscoTomcat
CiscoTomcat - stopping.
CiscoTomcat - stopped.
2011-11-21 11:37:37 : :  OK - Service Stopped Normally
2011-11-21 11:37:37 : : Stopping Cisco CallManager
Cisco CallManager - stopping.
Cisco CallManager - stopped.
2011-11-21 11:37:42 : :  OK - Service Stopped Normally
2011-11-21 11:37:42 : : Stopping ArtTomcat
    error code = 1060
2011-11-21 11:37:43 : :  OK - Service is not installed on this server
2011-11-21 11:37:43 : : Stopping ARTScheduler
ARTScheduler - stopping.
ARTScheduler - stopped.
2011-11-21 11:38:18 : :  OK - Service Stopped Normally
2011-11-21 11:38:18 : : Stopping Cisco Media Services Tomcat
    error code = 1060
2011-11-21 11:38:18 : :  OK - Service is not installed on this server
2011-11-21 11:38:18 : : Stopping w3svc
w3svc - stopping.
w3svc - stopped.
2011-11-21 11:38:23 : :  OK - Service Stopped Normally
2011-11-21 11:38:23 : : Stopping NetworkTimeProtocol
    error code = 1060
2011-11-21 11:38:23 : :  OK - Service is not installed on this server
2011-11-21 11:38:23 : : Stopping NTP
NTP - stopping.
NTP - stopped.
2011-11-21 11:38:28 : :  OK - Service Stopped Normally
2011-11-21 11:38:28 : : Stopping stiback
    error code = 1060
2011-11-21 11:38:28 : :  OK - Service is not installed on this server
2011-11-21 11:38:28 : : Stopping aupair
aupair - stopping.
aupair - stopped.
2011-11-21 11:38:38 : :  OK - Service Stopped Normally
2011-11-21 11:38:38 : : Stopping sysmonlog
sysmonlog - stopping.
sysmonlog - error stopping service:3
2011-11-21 11:38:39 : : OK - Service was already Stopped
2011-11-21 11:38:39 : : Stopping Cisco Application Engine
    error code = 1060
2011-11-21 11:38:39 : :  OK - Service is not installed on this server
2011-11-21 11:38:39 : : Stopping Cisco CRA Engine
    error code = 1060
2011-11-21 11:38:39 : : Stopping CiscoCRAServletEngine
    error code = 1060
2011-11-21 11:38:39 : : Stopping Cisco Purging Scheduler
    error code = 1060
2011-11-21 11:38:39 : : Stopping Cisco AVVID Alarm Service
Cisco AVVID Alarm Service - stopping.
Cisco AVVID Alarm Service - stopped.
2011-11-21 11:38:44 : :  OK - Service Stopped Normally
2011-11-21 11:38:44 : : Stopping FMMserver
    error code = 1060
2011-11-21 11:38:44 : :  OK - Service is not installed on this server
2011-11-21 11:38:44 : : Stopping AIC Server Agent 2.0
    error code = 1060
2011-11-21 11:38:45 : :  OK - Service is not installed on this server
2011-11-21 11:38:45 : : Stopping WinMgmt
WinMgmt - stopping.
    VMUpgradeHelper - stopping dependant service.
WinMgmt - stopped.
2011-11-21 11:38:55 : :  OK - Service Stopped Normally
2011-11-21 11:38:55 : : Stopping RemoteRegistry
RemoteRegistry - stopping.
RemoteRegistry - stopped.
2011-11-21 11:38:55 : : Stopping TAPS
    error code = 1060
2011-11-21 11:38:55 : :  OK - Service is not installed on this server
2011-11-21 11:38:55 : : Stopping Cisco Dialed Number Analyzer
    error code = 1060
2011-11-21 11:38:55 : : Stopping CSAgent
    error code = 1060
2011-11-21 11:38:55 : : Stopping Cisco CTL Provider
Cisco CTL Provider - stopping.
Cisco CTL Provider - stopped.
2011-11-21 11:39:01 : :  OK - Service Stopped Normally
2011-11-21 11:39:01 : : Stopping Cisco Serviceability Reporter
Cisco Serviceability Reporter - stopping.
Cisco Serviceability Reporter - stopped.
2011-11-21 11:39:06 : :  OK - Service Stopped Normally
2011-11-21 11:39:06 : : Stopping iisadmin
iisadmin - stopping.
iisadmin - stopped.
2011-11-21 11:39:16 : :  OK - Service Stopped Normally
2011-11-21 11:39:16 : : Stopping SQLSERVERAGENT
SQLSERVERAGENT - stopping.
SQLSERVERAGENT - stopped.
2011-11-21 11:39:21 : :  OK - Service Stopped Normally
2011-11-21 11:39:21 : : Stopping Cisco BARS Scheduler
Cisco BARS Scheduler - stopping.
Cisco BARS Scheduler - stopped.
2011-11-21 11:39:26 : :  OK - Service Stopped Normally
2011-11-21 11:39:26 : : Stopping SNMP
SNMP - stopping.
SNMP - stopped.
2011-11-21 11:39:56 : :  OK - Service Stopped Normally
2011-11-21 11:39:56 : : Stopping iisadmin
iisadmin - error stopping service:3
2011-11-21 11:39:56 : : OK - Service was already Stopped
2011-11-21 11:39:56 : : Stopping CDP
CDP - stopping.
CDP - stopped.
2011-11-21 11:39:56 : iexplore.exe Process is being ended if detected
2011-11-21 11:39:56 : mmc.exe Process is being ended if detected
2011-11-21 11:39:57 : sqlmangr.exe Process is being ended if detected
2011-11-21 11:39:57 : Stopping all COM+ Objects
2011-11-21 11:39:57 : Stopping All COM+ Components
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCN}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCN}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCMCIP}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCMCIP}
2011-11-21 11:39:57 : Shutting down DBL
2011-11-21 11:39:57 : Shutdown complete for DBL
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/tftp}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/tftp}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCMAdmin}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCMAdmin}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCMServiceTraceCollectionTool}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCMServiceTraceCollectionTool}
2011-11-21 11:39:57 : Shutting down COM+ Utilities
2011-11-21 11:39:57 : Shutdown complete for COM+ Utilities
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCMPluginsClient}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCMPluginsClient}
2011-11-21 11:39:57 : Shutting down COM+ QC Dead Letter Queue Listener
2011-11-21 11:39:57 : Shutdown complete for COM+ QC Dead Letter Queue Listener
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCMPluginsServer}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCMPluginsServer}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/PktCap}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/PktCap}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CiscoTomcatSecure}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CiscoTomcatSecure}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCMUser}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCMUser}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCMApi}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCMApi}
2011-11-21 11:39:57 : Shutting down .NET Utilities
2011-11-21 11:39:57 : Shutdown complete for .NET Utilities
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCMTraceAnalysis}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCMTraceAnalysis}
2011-11-21 11:39:57 : Shutting down IIS Utilities
2011-11-21 11:39:57 : Shutdown complete for IIS Utilities
2011-11-21 11:39:57 : Shutting down IIS In-Process Applications
2011-11-21 11:39:57 : Shutdown complete for IIS In-Process Applications
2011-11-21 11:39:57 : Shutting down IIS Out-Of-Process Pooled Applications
2011-11-21 11:39:57 : Shutdown complete for IIS Out-Of-Process Pooled Applications
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCMPD}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCMPD}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//root/BatFiles}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//root/BatFiles}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/BARS}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/BARS}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/TraceTool}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/TraceTool}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//root/art}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//root/art}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/RTMTReports}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/RTMTReports}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CiscoTomcat}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CiscoTomcat}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//root/BAT}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//root/BAT}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/Soap}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/Soap}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/CCMService}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/CCMService}
2011-11-21 11:39:57 : Shutting down IIS-{Default Web Site//Root/ccn/GW}
2011-11-21 11:39:57 : Shutdown complete for IIS-{Default Web Site//Root/ccn/GW}
2011-11-21 11:39:57 : Shutting down BARS
2011-11-21 11:39:57 : Shutdown complete for BARS
2011-11-21 11:39:57 : COM+ Components shut down, exiting
11:39:58: **** Begin UpdateLoadInfo.exe Installation Section ****
11:39:58: Backing up UpdateLoadInfo.exe
11:39:58: copying UpdateLoadInfo.exe
11:39:58: Verifying C:\program files\cisco\bin\UpdateLoadInfo.exe
11:39:58: C:\program files\cisco\bin\UpdateLoadInfo.exe was replaced successfully
11:39:58: **** Begin CcmPerfMon.dll Installation Section ****
11:39:58: Backing up CcmPerfMon.dll
11:39:58: copying CcmPerfMon.dll
11:39:58: Verifying C:\program files\cisco\bin\CcmPerfMon.dll
11:39:58: C:\program files\cisco\bin\CcmPerfMon.dll was replaced successfully
11:39:58: **** Begin CiscoMessagingInterface.exe Installation Section ****
11:39:59: Backing up CiscoMessagingInterface.exe
11:39:59: copying CiscoMessagingInterface.exe
11:39:59: Verifying C:\program files\cisco\bin\CiscoMessagingInterface.exe
11:39:59: C:\program files\cisco\bin\CiscoMessagingInterface.exe was replaced successfully
11:39:59: **** Begin CmiPerfMon.dll Installation Section ****
11:39:59: Backing up CmiPerfMon.dll
11:39:59: copying CmiPerfMon.dll
11:39:59: Verifying C:\program files\cisco\bin\CmiPerfMon.dll
11:39:59: C:\program files\cisco\bin\CmiPerfMon.dll was replaced successfully
11:39:59: **** Begin CTIManager.exe Installation Section ****
11:40:00: Backing up CTIManager.exe
11:40:00: copying CTIManager.exe
11:40:00: Verifying C:\program files\cisco\bin\CTIManager.exe
11:40:00: C:\program files\cisco\bin\CTIManager.exe was replaced successfully
11:40:00: **** Begin CtiMgrPerfMon.dll Installation Section ****
11:40:00: Backing up CtiMgrPerfMon.dll
11:40:00: copying CtiMgrPerfMon.dll
11:40:00: Verifying C:\program files\cisco\bin\CtiMgrPerfMon.dll
11:40:00: C:\program files\cisco\bin\CtiMgrPerfMon.dll was replaced successfully
11:40:00: **** Begin DBConvert.dll Installation Section ****
11:40:00: Backing up DBConvert.dll
11:40:01: copying DBConvert.dll
11:40:01: Verifying C:\program files\cisco\bin\DBConvert.dll
11:40:01: C:\program files\cisco\bin\DBConvert.dll was replaced successfully
11:40:01: **** Begin MediaAppPerfMon.dll Installation Section ****
11:40:01: Backing up MediaAppPerfMon.dll
11:40:01: copying MediaAppPerfMon.dll
11:40:01: Verifying C:\program files\cisco\bin\MediaAppPerfMon.dll
11:40:01: C:\program files\cisco\bin\MediaAppPerfMon.dll was replaced successfully
11:40:01: **** Begin TcdSrvPerfMon.dll Installation Section ****
11:40:01: Backing up TcdSrvPerfMon.dll
11:40:01: copying TcdSrvPerfMon.dll
11:40:01: Verifying C:\program files\cisco\bin\TcdSrvPerfMon.dll
11:40:01: C:\program files\cisco\bin\TcdSrvPerfMon.dll was replaced successfully
11:40:01: **** Begin TftpPerfMon.dll Installation Section ****
11:40:02: Backing up TftpPerfMon.dll
11:40:02: copying TftpPerfMon.dll
11:40:02: Verifying C:\program files\cisco\bin\TftpPerfMon.dll
11:40:02: C:\program files\cisco\bin\TftpPerfMon.dll was replaced successfully
11:40:02: **** Begin ccm.exe Installation Section ****
11:40:02: Backing up ccm.exe
11:40:02: copying ccm.exe
11:40:03: Verifying C:\program files\cisco\bin\ccm.exe
11:40:04: C:\program files\cisco\bin\ccm.exe was replaced successfully
11:40:04: **** Begin DBL.dll Installation Section ****
11:40:05: Backing up DBL.dll
11:40:05: copying DBL.dll
11:40:05: Verifying C:\program files\cisco\bin\DBL.dll
11:40:06: C:\program files\cisco\bin\DBL.dll was replaced successfully
11:40:06: **** Begin Ipvmsapp.exe Installation Section ****
11:40:06: Backing up Ipvmsapp.exe
11:40:06: copying Ipvmsapp.exe
11:40:06: Verifying C:\program files\cisco\bin\Ipvmsapp.exe
11:40:06: C:\program files\cisco\bin\Ipvmsapp.exe was replaced successfully
11:40:06: **** Begin AudioTranslator.exe Installation Section ****
11:40:06: Backing up AudioTranslator.exe
11:40:07: copying AudioTranslator.exe
11:40:07: Verifying C:\program files\cisco\bin\AudioTranslator.exe
11:40:07: C:\program files\cisco\bin\AudioTranslator.exe was replaced successfully
11:40:07: **** Begin Aupair.exe Installation Section ****
11:40:07: Backing up Aupair.exe
11:40:07: copying Aupair.exe
11:40:07: Verifying C:\program files\cisco\bin\Aupair.exe
11:40:07: C:\program files\cisco\bin\Aupair.exe was replaced successfully
11:40:07: **** Begin AupairChangeNotify.dll Installation Section ****
11:40:08: Backing up AupairChangeNotify.dll
11:40:08: copying AupairChangeNotify.dll
11:40:08: Verifying C:\program files\cisco\bin\AupairChangeNotify.dll
11:40:08: C:\program files\cisco\bin\AupairChangeNotify.dll was replaced successfully
11:40:08: **** Begin AuthFilt.dll Installation Section ****
11:40:08: Backing up AuthFilt.dll
11:40:08: copying AuthFilt.dll
11:40:08: Verifying C:\program files\cisco\bin\AuthFilt.dll
11:40:08: C:\program files\cisco\bin\AuthFilt.dll was replaced successfully
11:40:08: **** Begin CallBackService.exe Installation Section ****
11:40:09: Backing up CallBackService.exe
11:40:09: copying CallBackService.exe
11:40:09: Verifying C:\program files\cisco\bin\CallBackService.exe
11:40:09: C:\program files\cisco\bin\CallBackService.exe was replaced successfully
11:40:09: **** Begin capfService.exe Installation Section ****
11:40:09: Backing up capfService.exe
11:40:10: copying capfService.exe
11:40:10: Verifying C:\program files\cisco\bin\capfService.exe
11:40:11: C:\program files\cisco\bin\capfService.exe was replaced successfully
11:40:11: **** Begin CBBDBChangeNotify.dll Installation Section ****
11:40:12: Backing up CBBDBChangeNotify.dll
11:40:12: copying CBBDBChangeNotify.dll
11:40:12: Verifying C:\program files\cisco\bin\CBBDBChangeNotify.dll
11:40:12: C:\program files\cisco\bin\CBBDBChangeNotify.dll was replaced successfully
11:40:12: **** Begin ctftp.exe Installation Section ****
11:40:12: Backing up ctftp.exe
11:40:12: copying ctftp.exe
11:40:12: Verifying C:\program files\cisco\bin\ctftp.exe
11:40:13: C:\program files\cisco\bin\ctftp.exe was replaced successfully
11:40:13: **** Begin CtftpChangeNotify.dll Installation Section ****
11:40:13: Backing up CtftpChangeNotify.dll
11:40:13: copying CtftpChangeNotify.dll
11:40:13: Verifying C:\program files\cisco\bin\CtftpChangeNotify.dll
11:40:13: C:\program files\cisco\bin\CtftpChangeNotify.dll was replaced successfully
11:40:13: **** Begin CtiDbChangeNotify.dll Installation Section ****
11:40:14: Backing up CtiDbChangeNotify.dll
11:40:14: copying CtiDbChangeNotify.dll
11:40:14: Verifying C:\program files\cisco\bin\CtiDbChangeNotify.dll
11:40:14: C:\program files\cisco\bin\CtiDbChangeNotify.dll was replaced successfully
11:40:14: **** Begin CTLProvider.exe Installation Section ****
11:40:14: Backing up CTLProvider.exe
11:40:14: copying CTLProvider.exe
11:40:14: Verifying C:\program files\cisco\bin\CTLProvider.exe
11:40:14: C:\program files\cisco\bin\CTLProvider.exe was replaced successfully
11:40:14: **** Begin DBChangeNotify.dll Installation Section ****
11:40:14: Backing up DBChangeNotify.dll
11:40:15: copying DBChangeNotify.dll
11:40:15: Verifying C:\program files\cisco\bin\DBChangeNotify.dll
11:40:15: C:\program files\cisco\bin\DBChangeNotify.dll was replaced successfully
11:40:15: **** Begin DBLR.dll Installation Section ****
11:40:15: Backing up DBLR.dll
11:40:15: copying DBLR.dll
11:40:15: Verifying C:\program files\cisco\bin\DBLR.dll
11:40:15: C:\program files\cisco\bin\DBLR.dll was replaced successfully
11:40:15: **** Begin DBLRT.dll Installation Section ****
11:40:15: Backing up DBLRT.dll
11:40:15: copying DBLRT.dll
11:40:15: Verifying C:\program files\cisco\bin\DBLRT.dll
11:40:15: C:\program files\cisco\bin\DBLRT.dll was replaced successfully
11:40:15: **** Begin DBLX.dll Installation Section ****
11:40:16: Backing up DBLX.dll
11:40:16: copying DBLX.dll
11:40:16: Verifying C:\program files\cisco\bin\DBLX.dll
11:40:17: C:\program files\cisco\bin\DBLX.dll was replaced successfully
11:40:17: **** Begin DBNotify.dll Installation Section ****
11:40:17: Backing up DBNotify.dll
11:40:17: copying DBNotify.dll
11:40:17: Verifying C:\program files\cisco\bin\DBNotify.dll
11:40:17: C:\program files\cisco\bin\DBNotify.dll was replaced successfully
11:40:17: **** Begin DNAChangeNotify.dll Installation Section ****
11:40:17: Backing up DNAChangeNotify.dll
11:40:17: copying DNAChangeNotify.dll
11:40:17: Verifying C:\program files\cisco\bin\DNAChangeNotify.dll
11:40:17: C:\program files\cisco\bin\DNAChangeNotify.dll was replaced successfully
11:40:17: **** Begin InsertCDR.exe Installation Section ****
11:40:18: Backing up InsertCDR.exe
11:40:18: copying InsertCDR.exe
11:40:18: Verifying C:\program files\cisco\bin\InsertCDR.exe
11:40:18: C:\program files\cisco\bin\InsertCDR.exe was replaced successfully
11:40:18: **** Begin IpVMSChangeNotify.dll Installation Section ****
11:40:18: Backing up IpVMSChangeNotify.dll
11:40:18: copying IpVMSChangeNotify.dll
11:40:18: Verifying C:\program files\cisco\bin\IpVMSChangeNotify.dll
11:40:18: C:\program files\cisco\bin\IpVMSChangeNotify.dll was replaced successfully
11:40:18: **** Begin MMFSpy.exe Installation Section ****
11:40:18: Backing up MMFSpy.exe
11:40:18: copying MMFSpy.exe
11:40:18: Verifying C:\program files\cisco\bin\MMFSpy.exe
11:40:19: C:\program files\cisco\bin\MMFSpy.exe was replaced successfully
11:40:19: **** Begin perfport.dll Installation Section ****
11:40:19: Backing up perfport.dll
11:40:19: copying perfport.dll
11:40:19: Verifying C:\program files\cisco\bin\perfport.dll
11:40:19: C:\program files\cisco\bin\perfport.dll was replaced successfully
11:40:19: **** Begin RisDC.exe Installation Section ****
11:40:19: Backing up RisDC.exe
11:40:19: copying RisDC.exe
11:40:19: Verifying C:\program files\cisco\bin\RisDC.exe
11:40:20: C:\program files\cisco\bin\RisDC.exe was replaced successfully
11:40:20: **** Begin risport.dll Installation Section ****
11:40:20: Backing up risport.dll
11:40:20: copying risport.dll
11:40:20: Verifying C:\program files\cisco\bin\risport.dll
11:40:21: C:\program files\cisco\bin\risport.dll was replaced successfully
11:40:21: **** Begin RISX.dll Installation Section ****
11:40:21: Backing up RISX.dll
11:40:21: copying RISX.dll
11:40:21: Verifying C:\program files\cisco\bin\RISX.dll
11:40:21: C:\program files\cisco\bin\RISX.dll was replaced successfully
11:40:21: **** Begin SnmpCcmImpl.dll Installation Section ****
11:40:22: Backing up SnmpCcmImpl.dll
11:40:22: copying SnmpCcmImpl.dll
11:40:22: Verifying C:\program files\cisco\bin\SnmpCcmImpl.dll
11:40:22: C:\program files\cisco\bin\SnmpCcmImpl.dll was replaced successfully
11:40:22: **** Begin SSAPIDLL.dll Installation Section ****
11:40:22: Backing up SSAPIDLL.dll
11:40:22: copying SSAPIDLL.dll
11:40:22: Verifying C:\program files\cisco\bin\SSAPIDLL.dll
11:40:22: C:\program files\cisco\bin\SSAPIDLL.dll was replaced successfully
11:40:22: **** Begin TCDSvrDBCN.dll Installation Section ****
11:40:22: Backing up TCDSvrDBCN.dll
11:40:22: copying TCDSvrDBCN.dll
11:40:22: Verifying C:\program files\cisco\bin\TCDSvrDBCN.dll
11:40:22: C:\program files\cisco\bin\TCDSvrDBCN.dll was replaced successfully
11:40:22: **** Begin QRTFileMgr.exe Installation Section ****
11:40:23: Backing up QRTFileMgr.exe
11:40:23: copying QRTFileMgr.exe
11:40:23: Verifying C:\program files\cisco\bin\QRTFileMgr.exe
11:40:23: C:\program files\cisco\bin\QRTFileMgr.exe was replaced successfully
11:40:23: **** Begin UserPermissions.dll Installation Section ****
11:40:23: Backing up UserPermissions.dll
11:40:23: copying UserPermissions.dll
11:40:23: Verifying C:\program files\cisco\bin\UserPermissions.dll
11:40:23: C:\program files\cisco\bin\UserPermissions.dll was replaced successfully
11:40:23: **** Begin UserPermissionsX.dll Installation Section ****
11:40:23: Backing up UserPermissionsX.dll
11:40:23: copying UserPermissionsX.dll
11:40:23: Verifying C:\program files\cisco\bin\UserPermissionsX.dll
11:40:24: C:\program files\cisco\bin\UserPermissionsX.dll was replaced successfully
11:40:24: **** Begin CertGen.exe Installation Section ****
11:40:24: Backing up CertGen.exe
11:40:24: copying CertGen.exe
11:40:24: Verifying C:\program files\cisco\bin\CertGen.exe
11:40:24: C:\program files\cisco\bin\CertGen.exe was replaced successfully
11:40:24: **** Begin CertInstall.exe Installation Section ****
11:40:24: Backing up CertInstall.exe
11:40:24: copying CertInstall.exe
11:40:24: Verifying C:\program files\cisco\bin\CertInstall.exe
11:40:24: C:\program files\cisco\bin\CertInstall.exe was replaced successfully
11:40:24: **** Begin md5util.exe Installation Section ****
11:40:24: Backing up md5util.exe
11:40:25: copying md5util.exe
11:40:25: Verifying C:\program files\cisco\bin\md5util.exe
11:40:25: C:\program files\cisco\bin\md5util.exe was replaced successfully
11:40:25: **** Begin CryptoUtil.dll Installation Section ****
11:40:25: Backing up CryptoUtil.dll
11:40:25: copying CryptoUtil.dll
11:40:25: Verifying C:\program files\cisco\bin\CryptoUtil.dll
11:40:25: C:\program files\cisco\bin\CryptoUtil.dll was replaced successfully
11:40:25: **** Begin CryptoUtil_ne.dll Installation Section ****
11:40:25: copying CryptoUtil_ne.dll
11:40:25: Verifying C:\program files\cisco\bin\CryptoUtil_ne.dll
11:40:25: C:\program files\cisco\bin\CryptoUtil_ne.dll was replaced successfully
11:40:25: **** Begin libeay32.dll Installation Section ****
11:40:25: Backing up libeay32.dll
11:40:25: copying libeay32.dll
11:40:25: Verifying C:\program files\cisco\bin\libeay32.dll
11:40:26: C:\program files\cisco\bin\libeay32.dll was replaced successfully
11:40:26: **** Begin PktCapEx.dll Installation Section ****
11:40:26: Backing up PktCapEx.dll
11:40:26: copying PktCapEx.dll
11:40:26: Verifying C:\program files\cisco\bin\PktCapEx.dll
11:40:26: C:\program files\cisco\bin\PktCapEx.dll was replaced successfully
11:40:26: **** Begin ssleay32.dll Installation Section ****
11:40:26: Backing up ssleay32.dll
11:40:26: copying ssleay32.dll
11:40:26: Verifying C:\program files\cisco\bin\ssleay32.dll
11:40:26: C:\program files\cisco\bin\ssleay32.dll was replaced successfully
11:40:26: **** Begin dbinstall.dll Installation Section ****
11:40:26: Backing up dbinstall.dll
11:40:27: copying dbinstall.dll
11:40:27: Verifying C:\program files\cisco\bin\dbinstall.dll
11:40:27: C:\program files\cisco\bin\dbinstall.dll was replaced successfully
11:40:27: **** Begin ccme_base.dll Installation Section ****
11:40:27: copying ccme_base.dll
11:40:27: Verifying C:\program files\cisco\bin\ccme_base.dll
11:40:27: C:\program files\cisco\bin\ccme_base.dll was replaced successfully
11:40:27: **** Begin ccme_ecc.dll Installation Section ****
11:40:27: copying ccme_ecc.dll
11:40:27: Verifying C:\program files\cisco\bin\ccme_ecc.dll
11:40:27: C:\program files\cisco\bin\ccme_ecc.dll was replaced successfully
11:40:27: **** Begin ccme_eccaccel.dll Installation Section ****
11:40:27: copying ccme_eccaccel.dll
11:40:27: Verifying C:\program files\cisco\bin\ccme_eccaccel.dll
11:40:28: C:\program files\cisco\bin\ccme_eccaccel.dll was replaced successfully
11:40:28: **** Begin cryptocme2.dll Installation Section ****
11:40:28: copying cryptocme2.dll
11:40:28: Verifying C:\program files\cisco\bin\cryptocme2.dll
11:40:28: C:\program files\cisco\bin\cryptocme2.dll was replaced successfully
11:40:28: **** Begin cryptocme2.sig Installation Section ****
11:40:28: copying cryptocme2.sig
11:40:28: Verifying C:\program files\cisco\bin\cryptocme2.sig
11:40:28: C:\program files\cisco\bin\cryptocme2.sig was replaced successfully
11:40:28: Backing up C:\program files\cisco\bin\xmltemp\xml\
11:40:28: Copying CCM Display Instance.xml to C:\program files\cisco\bin\xmltemp\xml
11:40:28: Verifying "C:\program files\cisco\bin\xmltemp\xml\CCM Display Instance.xml
11:40:28: C:\program files\cisco\bin\xmltemp\xml\CCM Display Instance.xml was replaced successfully
11:40:28: Copying CCM Rules.xml to C:\program files\cisco\bin\xmltemp\xml
11:40:29: Verifying "C:\program files\cisco\bin\xmltemp\xml\CCM Rules.xml
11:40:29: C:\program files\cisco\bin\xmltemp\xml\CCM Rules.xml was replaced successfully
11:40:29: Backing up C:\program files\Cisco\CallManager\DBInstallCSV\
11:40:29: Copying TypeASPToMenuIndexMap.csv to C:\program files\Cisco\CallManager\DBInstallCSV
11:40:29: Verifying "C:\program files\Cisco\CallManager\DBInstallCSV\TypeASPToMenuIndexMap.csv
11:40:29: C:\program files\Cisco\CallManager\DBInstallCSV\TypeASPToMenuIndexMap.csv was replaced successfully
11:40:29: Copying TypeTimeZone.csv to C:\program files\Cisco\CallManager\DBInstallCSV
11:40:29: Verifying "C:\program files\Cisco\CallManager\DBInstallCSV\TypeTimeZone.csv
11:40:29: C:\program files\Cisco\CallManager\DBInstallCSV\TypeTimeZone.csv was replaced successfully
11:40:29: Backing up C:\CiscoPlugins\Server\
11:40:29: Copying CiscoTSP.exe to C:\CiscoPlugins\Server
11:40:29: Verifying "C:\CiscoPlugins\Server\CiscoTSP.exe
11:40:30: C:\CiscoPlugins\Server\CiscoTSP.exe was replaced successfully
11:40:30: Backing up C:\CiscoPlugins\Server\
11:40:30: Copying BulkAdministrationTool.exe to C:\CiscoPlugins\Server
11:40:30: Verifying "C:\CiscoPlugins\Server\BulkAdministrationTool.exe
11:40:31: C:\CiscoPlugins\Server\BulkAdministrationTool.exe was replaced successfully
11:40:31: Backing up C:\CiscoPlugins\Server\
11:40:31: Copying CiscoJTAPIClient.exe to C:\CiscoPlugins\Server
11:40:31: Verifying "C:\CiscoPlugins\Server\CiscoJTAPIClient.exe
11:40:32: C:\CiscoPlugins\Server\CiscoJTAPIClient.exe was replaced successfully
11:40:32: Backing up C:\CiscoPlugins\Server\
11:40:32: Copying jtapi.jar to C:\CiscoPlugins\Server
11:40:32: Verifying "C:\CiscoPlugins\Server\jtapi.jar
11:40:32: C:\CiscoPlugins\Server\jtapi.jar was replaced successfully
11:40:32: Copying jtracing.jar to C:\CiscoPlugins\Server
11:40:32: Verifying "C:\CiscoPlugins\Server\jtracing.jar
11:40:33: C:\CiscoPlugins\Server\jtracing.jar was replaced successfully
11:40:33: Backing up c:\ciscoplugins\client\
11:40:33: Copying CiscoAttendantConsoleClient.exe to c:\ciscoplugins\client
11:40:34: Verifying "c:\ciscoplugins\client\CiscoAttendantConsoleClient.exe
11:40:35: c:\ciscoplugins\client\CiscoAttendantConsoleClient.exe was replaced successfully
11:40:35: Backing up c:\ciscoplugins\client\
11:40:35: Copying CcmServRtmtPlugin.exe to c:\ciscoplugins\client
11:40:36: Verifying "c:\ciscoplugins\client\CcmServRtmtPlugin.exe
11:40:37: c:\ciscoplugins\client\CcmServRtmtPlugin.exe was replaced successfully
11:40:37: Backing up c:\ciscowebs\admin\
11:40:37: Copying usermainpage.asp to c:\ciscowebs\admin
11:40:37: Verifying "c:\ciscowebs\admin\usermainpage.asp
11:40:37: c:\ciscowebs\admin\usermainpage.asp was replaced successfully
11:40:37: Copying sccpconfig.asp to c:\ciscowebs\admin
11:40:37: Verifying "c:\ciscowebs\admin\sccpconfig.asp
11:40:38: c:\ciscowebs\admin\sccpconfig.asp was replaced successfully
11:40:38: Backing up c:\ciscowebs\admin\
11:40:38: Copying phoneconfig.asp to c:\ciscowebs\admin
11:40:38: Verifying "c:\ciscowebs\admin\phoneconfig.asp
11:40:38: c:\ciscowebs\admin\phoneconfig.asp was replaced successfully
11:40:38: Copying timescheduleconfig.asp to c:\ciscowebs\admin
11:40:38: Verifying "c:\ciscowebs\admin\timescheduleconfig.asp
11:40:38: c:\ciscowebs\admin\timescheduleconfig.asp was replaced successfully
11:40:38: Copying routepartitionconfig.asp to c:\ciscowebs\admin
11:40:38: Verifying "c:\ciscowebs\admin\routepartitionconfig.asp
11:40:38: c:\ciscowebs\admin\routepartitionconfig.asp was replaced successfully
11:40:39: Backing up c:\ciscowebs\user\
11:40:39: Copying global.asa to c:\ciscowebs\user
11:40:39: Verifying "c:\ciscowebs\user\global.asa
11:40:39: c:\ciscowebs\user\global.asa was replaced successfully
11:40:39: Copying _top.asp to c:\ciscowebs\user
11:40:39: Verifying "c:\ciscowebs\user\_top.asp
11:40:39: c:\ciscowebs\user\_top.asp was replaced successfully
11:40:39: Backing up c:\ciscowebs\service\
11:40:39: Copying QRTReportResult.asp to c:\ciscowebs\service
11:40:39: Verifying "c:\ciscowebs\service\QRTReportResult.asp
11:40:39: c:\ciscowebs\service\QRTReportResult.asp was replaced successfully
11:40:39: Resetting File Attributes on file "c:\CiscoWebs\AST\AST.jar"
11:40:39: Backing up c:\CiscoWebs\AST\AST.jar
11:40:39: Copying AST.jar to c:\CiscoWebs\AST
11:40:39: Verifying c:\CiscoWebs\AST\AST.jar
11:40:40: c:\CiscoWebs\AST\AST.jar was replaced successfully
11:40:40: Resetting File Attributes on file "C:\DCDSrvr\Lib\CiscoPWDChanger.dll"
11:40:40: Backing up C:\DCDSrvr\Lib\CiscoPWDChanger.dll
11:40:40: Copying CiscoPWDChanger.dll to C:\DCDSrvr\Lib
11:40:40: Verifying C:\DCDSrvr\Lib\CiscoPWDChanger.dll
11:40:40: C:\DCDSrvr\Lib\CiscoPWDChanger.dll was replaced successfully
11:40:40: Resetting File Attributes on file "C:\DCDSrvr\Libjava\DirUser.jar"
11:40:40: Backing up C:\DCDSrvr\Libjava\DirUser.jar
11:40:40: Copying DirUser.jar to C:\DCDSrvr\Libjava
11:40:40: Verifying C:\DCDSrvr\Libjava\DirUser.jar
11:40:40: C:\DCDSrvr\Libjava\DirUser.jar was replaced successfully
11:40:40: Resetting File Attributes on file "C:\Program Files\Cisco\ApplicationJars\JavaNcsClient.jar"
11:40:40: Backing up C:\Program Files\Cisco\ApplicationJars\JavaNcsClient.jar
11:40:41: Copying JavaNcsClient.jar to C:\Program Files\Cisco\ApplicationJars
11:40:41: Verifying C:\Program Files\Cisco\ApplicationJars\JavaNcsClient.jar
11:40:41: C:\Program Files\Cisco\ApplicationJars\JavaNcsClient.jar was replaced successfully
11:40:41: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\bin\accollectlogs.bat"
11:40:41: Backing up c:\Program Files\Cisco\callmanagerattendant\bin\accollectlogs.bat
11:40:41: Copying accollectlogs.bat to c:\Program Files\Cisco\callmanagerattendant\bin
11:40:41: Verifying c:\Program Files\Cisco\callmanagerattendant\bin\accollectlogs.bat
11:40:41: c:\Program Files\Cisco\callmanagerattendant\bin\accollectlogs.bat was replaced successfully
11:40:41: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\bin\acconfig.bat"
11:40:41: Backing up c:\Program Files\Cisco\callmanagerattendant\bin\acconfig.bat
11:40:41: Copying acconfig.bat to c:\Program Files\Cisco\callmanagerattendant\bin
11:40:41: Verifying c:\Program Files\Cisco\callmanagerattendant\bin\acconfig.bat
11:40:41: c:\Program Files\Cisco\callmanagerattendant\bin\acconfig.bat was replaced successfully
11:40:42: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\bin\acenc.exe"
11:40:42: Backing up c:\Program Files\Cisco\callmanagerattendant\bin\acenc.exe
11:40:42: Copying acenc.exe to c:\Program Files\Cisco\callmanagerattendant\bin
11:40:42: Verifying c:\Program Files\Cisco\callmanagerattendant\bin\acenc.exe
11:40:42: c:\Program Files\Cisco\callmanagerattendant\bin\acenc.exe was replaced successfully
11:40:42: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\bin\ACNative.dll"
11:40:42: Backing up c:\Program Files\Cisco\callmanagerattendant\bin\ACNative.dll
11:40:42: Copying ACNative.dll to c:\Program Files\Cisco\callmanagerattendant\bin
11:40:42: Verifying c:\Program Files\Cisco\callmanagerattendant\bin\ACNative.dll
11:40:42: c:\Program Files\Cisco\callmanagerattendant\bin\ACNative.dll was replaced successfully
11:40:42: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\bin\builddir.bat"
11:40:42: Backing up c:\Program Files\Cisco\callmanagerattendant\bin\builddir.bat
11:40:42: Copying builddir.bat to c:\Program Files\Cisco\callmanagerattendant\bin
11:40:42: Verifying c:\Program Files\Cisco\callmanagerattendant\bin\builddir.bat
11:40:42: c:\Program Files\Cisco\callmanagerattendant\bin\builddir.bat was replaced successfully
11:40:42: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\bin\RegistryCtl.dll"
11:40:43: Backing up c:\Program Files\Cisco\callmanagerattendant\bin\RegistryCtl.dll
11:40:43: Copying RegistryCtl.dll to c:\Program Files\Cisco\callmanagerattendant\bin
11:40:43: Verifying c:\Program Files\Cisco\callmanagerattendant\bin\RegistryCtl.dll
11:40:43: c:\Program Files\Cisco\callmanagerattendant\bin\RegistryCtl.dll was replaced successfully
11:40:43: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\bin\tcdsrv.exe"
11:40:43: Backing up c:\Program Files\Cisco\callmanagerattendant\bin\tcdsrv.exe
11:40:43: Copying tcdsrv.exe to c:\Program Files\Cisco\callmanagerattendant\bin
11:40:43: Verifying c:\Program Files\Cisco\callmanagerattendant\bin\tcdsrv.exe
11:40:43: c:\Program Files\Cisco\callmanagerattendant\bin\tcdsrv.exe was replaced successfully
11:40:43: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\etc\Dialogs.properties"
11:40:43: Backing up c:\Program Files\Cisco\callmanagerattendant\etc\Dialogs.properties
11:40:43: Copying Dialogs.properties to c:\Program Files\Cisco\callmanagerattendant\etc
11:40:43: Verifying c:\Program Files\Cisco\callmanagerattendant\etc\Dialogs.properties
11:40:43: c:\Program Files\Cisco\callmanagerattendant\etc\Dialogs.properties was replaced successfully
11:40:43: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\etc\DialRulesExample.xml"
11:40:43: Backing up c:\Program Files\Cisco\callmanagerattendant\etc\DialRulesExample.xml
11:40:44: Copying DialRulesExample.xml to c:\Program Files\Cisco\callmanagerattendant\etc
11:40:44: Verifying c:\Program Files\Cisco\callmanagerattendant\etc\DialRulesExample.xml
11:40:44: c:\Program Files\Cisco\callmanagerattendant\etc\DialRulesExample.xml was replaced successfully
11:40:44: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\etc\GlobalUI.properties"
11:40:44: Backing up c:\Program Files\Cisco\callmanagerattendant\etc\GlobalUI.properties
11:40:44: Copying GlobalUI.properties to c:\Program Files\Cisco\callmanagerattendant\etc
11:40:44: Verifying c:\Program Files\Cisco\callmanagerattendant\etc\GlobalUI.properties
11:40:44: c:\Program Files\Cisco\callmanagerattendant\etc\GlobalUI.properties was replaced successfully
11:40:44: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\etc\LocaleListing.properties"
11:40:44: Backing up c:\Program Files\Cisco\callmanagerattendant\etc\LocaleListing.properties
11:40:44: Copying LocaleListing.properties to c:\Program Files\Cisco\callmanagerattendant\etc
11:40:44: Verifying c:\Program Files\Cisco\callmanagerattendant\etc\LocaleListing.properties
11:40:44: c:\Program Files\Cisco\callmanagerattendant\etc\LocaleListing.properties was replaced successfully
11:40:44: Resetting File Attributes on file "c:\Program Files\Cisco\callmanagerattendant\etc\Messages.properties"
11:40:44: Backing up c:\Program Files\Cisco\callmanagerattendant\etc\Messages.properties
11:40:44: Copying Messages.properties to c:\Program Files\Cisco\callmanagerattendant\etc
11:40:44: Verifying c:\Program Files\Cisco\callmanagerattendant\etc\Messages.properties
11:40:45: c:\Program Files\Cisco\callmanagerattendant\etc\Messages.properties was replaced successfully
11:40:45: Resetting File Attributes on file "C:\Program Files\Cisco\callmanagerattendant\lib\ac.jar"
11:40:45: Backing up C:\Program Files\Cisco\callmanagerattendant\lib\ac.jar
11:40:45: Copying ac.jar to C:\Program Files\Cisco\callmanagerattendant\lib
11:40:45: Verifying C:\Program Files\Cisco\callmanagerattendant\lib\ac.jar
11:40:45: C:\Program Files\Cisco\callmanagerattendant\lib\ac.jar was replaced successfully
11:40:45: Resetting File Attributes on file "C:\Program Files\Cisco\callmanagerattendant\lib\crimson.jar"
11:40:45: Backing up C:\Program Files\Cisco\callmanagerattendant\lib\crimson.jar
11:40:45: Copying crimson.jar to C:\Program Files\Cisco\callmanagerattendant\lib
11:40:45: Verifying C:\Program Files\Cisco\callmanagerattendant\lib\crimson.jar
11:40:45: C:\Program Files\Cisco\callmanagerattendant\lib\crimson.jar was replaced successfully
11:40:46: Resetting File Attributes on file "C:\Program Files\Cisco\callmanagerattendant\lib\ldapbp.jar"
11:40:46: Backing up C:\Program Files\Cisco\callmanagerattendant\lib\ldapbp.jar
11:40:46: Copying ldapbp.jar to C:\Program Files\Cisco\callmanagerattendant\lib
11:40:46: Verifying C:\Program Files\Cisco\callmanagerattendant\lib\ldapbp.jar
11:40:46: C:\Program Files\Cisco\callmanagerattendant\lib\ldapbp.jar was replaced successfully
11:40:46: Resetting File Attributes on file "C:\Program Files\Cisco\callmanagerattendant\lib\log4j.jar"
11:40:46: Backing up C:\Program Files\Cisco\callmanagerattendant\lib\log4j.jar
11:40:46: Copying log4j.jar to C:\Program Files\Cisco\callmanagerattendant\lib
11:40:46: Verifying C:\Program Files\Cisco\callmanagerattendant\lib\log4j.jar
11:40:46: C:\Program Files\Cisco\callmanagerattendant\lib\log4j.jar was replaced successfully
11:40:46: Resetting File Attributes on file "c:\Program Files\Cisco\Common\GetVersionInfoFromJar.dll"
11:40:46: Backing up c:\Program Files\Cisco\Common\GetVersionInfoFromJar.dll
11:40:46: Copying GetVersionInfoFromJar.dll to c:\Program Files\Cisco\Common
11:40:46: Verifying c:\Program Files\Cisco\Common\GetVersionInfoFromJar.dll
11:40:46: c:\Program Files\Cisco\Common\GetVersionInfoFromJar.dll was replaced successfully
11:40:46: Resetting File Attributes on file "C:\Program Files\Cisco\Common\IpVms.sys"
11:40:47: Backing up C:\Program Files\Cisco\Common\IpVms.sys
11:40:47: Copying IpVms.sys to C:\Program Files\Cisco\Common
11:40:47: Verifying C:\Program Files\Cisco\Common\IpVms.sys
11:40:47: C:\Program Files\Cisco\Common\IpVms.sys was replaced successfully
11:40:47: Resetting File Attributes on file "C:\Program Files\Cisco\ServiceabilityReporter\RTMT\LIB\RTMTReporter.jar"
11:40:47: Backing up C:\Program Files\Cisco\ServiceabilityReporter\RTMT\LIB\RTMTReporter.jar
11:40:47: Copying RTMTReporter.jar to C:\Program Files\Cisco\ServiceabilityReporter\RTMT\LIB
11:40:47: Verifying C:\Program Files\Cisco\ServiceabilityReporter\RTMT\LIB\RTMTReporter.jar
11:40:47: C:\Program Files\Cisco\ServiceabilityReporter\RTMT\LIB\RTMTReporter.jar was replaced successfully
11:40:47: Resetting File Attributes on file "C:\Program Files\Cisco\Bin\Xmltemp\AlarmCatalog\ccmalarms.html"
11:40:47: Backing up C:\Program Files\Cisco\Bin\Xmltemp\AlarmCatalog\ccmalarms.html
11:40:47: Copying ccmalarms.html to C:\Program Files\Cisco\Bin\Xmltemp\AlarmCatalog
11:40:47: Verifying C:\Program Files\Cisco\Bin\Xmltemp\AlarmCatalog\ccmalarms.html
11:40:48: C:\Program Files\Cisco\Bin\Xmltemp\AlarmCatalog\ccmalarms.html was replaced successfully
11:40:48: Resetting File Attributes on file "C:\Program Files\Cisco\TomCat\webapps\webdialer\webdialer.war"
11:40:48: Backing up C:\Program Files\Cisco\TomCat\webapps\webdialer\webdialer.war
11:40:48: Copying webdialer.war to C:\Program Files\Cisco\TomCat\webapps\webdialer
11:40:48: Verifying C:\Program Files\Cisco\TomCat\webapps\webdialer\webdialer.war
11:40:48: C:\Program Files\Cisco\TomCat\webapps\webdialer\webdialer.war was replaced successfully
11:40:48: Resetting File Attributes on file "C:\Program Files\Cisco\TomCat\webapps\MA\ma.war"
11:40:48: Backing up C:\Program Files\Cisco\TomCat\webapps\MA\ma.war
11:40:48: Copying ma.war to C:\Program Files\Cisco\TomCat\webapps\MA
11:40:48: Verifying C:\Program Files\Cisco\TomCat\webapps\MA\ma.war
11:40:49: C:\Program Files\Cisco\TomCat\webapps\MA\ma.war was replaced successfully
11:40:49: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7940 IPMAAssistantPhoneBATTemplate.txt"
11:40:49: Backing up C:\Program Files\Cisco\MA\inputBAT\7940 IPMAAssistantPhoneBATTemplate.txt
11:40:49: Copying 7940 IPMAAssistantPhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:49: Verifying C:\Program Files\Cisco\MA\inputBAT\7940 IPMAAssistantPhoneBATTemplate.txt
11:40:50: C:\Program Files\Cisco\MA\inputBAT\7940 IPMAAssistantPhoneBATTemplate.txt was replaced successfully
11:40:50: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7940 IPMAEveryonePhoneBATTemplate.txt"
11:40:50: Backing up C:\Program Files\Cisco\MA\inputBAT\7940 IPMAEveryonePhoneBATTemplate.txt
11:40:50: Copying 7940 IPMAEveryonePhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:50: Verifying C:\Program Files\Cisco\MA\inputBAT\7940 IPMAEveryonePhoneBATTemplate.txt
11:40:50: C:\Program Files\Cisco\MA\inputBAT\7940 IPMAEveryonePhoneBATTemplate.txt was replaced successfully
11:40:50: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7940 IPMAManagerPhoneBATTemplate.txt"
11:40:50: Backing up C:\Program Files\Cisco\MA\inputBAT\7940 IPMAManagerPhoneBATTemplate.txt
11:40:50: Copying 7940 IPMAManagerPhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:50: Verifying C:\Program Files\Cisco\MA\inputBAT\7940 IPMAManagerPhoneBATTemplate.txt
11:40:50: C:\Program Files\Cisco\MA\inputBAT\7940 IPMAManagerPhoneBATTemplate.txt was replaced successfully
11:40:50: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7940 IPMAManagerPhoneBATUDPTemplate.txt"
11:40:50: Backing up C:\Program Files\Cisco\MA\inputBAT\7940 IPMAManagerPhoneBATUDPTemplate.txt
11:40:50: Copying 7940 IPMAManagerPhoneBATUDPTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:50: Verifying C:\Program Files\Cisco\MA\inputBAT\7940 IPMAManagerPhoneBATUDPTemplate.txt
11:40:51: C:\Program Files\Cisco\MA\inputBAT\7940 IPMAManagerPhoneBATUDPTemplate.txt was replaced successfully
11:40:51: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7960 IPMAAssistantPhoneBATTemplate.txt"
11:40:51: Backing up C:\Program Files\Cisco\MA\inputBAT\7960 IPMAAssistantPhoneBATTemplate.txt
11:40:51: Copying 7960 IPMAAssistantPhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:51: Verifying C:\Program Files\Cisco\MA\inputBAT\7960 IPMAAssistantPhoneBATTemplate.txt
11:40:51: C:\Program Files\Cisco\MA\inputBAT\7960 IPMAAssistantPhoneBATTemplate.txt was replaced successfully
11:40:51: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7960 IPMAEveryonePhoneBATTemplate.txt"
11:40:51: Backing up C:\Program Files\Cisco\MA\inputBAT\7960 IPMAEveryonePhoneBATTemplate.txt
11:40:51: Copying 7960 IPMAEveryonePhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:51: Verifying C:\Program Files\Cisco\MA\inputBAT\7960 IPMAEveryonePhoneBATTemplate.txt
11:40:51: C:\Program Files\Cisco\MA\inputBAT\7960 IPMAEveryonePhoneBATTemplate.txt was replaced successfully
11:40:51: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7960 IPMAManagerPhoneBATTemplate.txt"
11:40:51: Backing up C:\Program Files\Cisco\MA\inputBAT\7960 IPMAManagerPhoneBATTemplate.txt
11:40:51: Copying 7960 IPMAManagerPhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:51: Verifying C:\Program Files\Cisco\MA\inputBAT\7960 IPMAManagerPhoneBATTemplate.txt
11:40:51: C:\Program Files\Cisco\MA\inputBAT\7960 IPMAManagerPhoneBATTemplate.txt was replaced successfully
11:40:52: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7960 IPMAManagerPhoneBATUDPTemplate.txt"
11:40:52: Backing up C:\Program Files\Cisco\MA\inputBAT\7960 IPMAManagerPhoneBATUDPTemplate.txt
11:40:52: Copying 7960 IPMAManagerPhoneBATUDPTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:52: Verifying C:\Program Files\Cisco\MA\inputBAT\7960 IPMAManagerPhoneBATUDPTemplate.txt
11:40:52: C:\Program Files\Cisco\MA\inputBAT\7960 IPMAManagerPhoneBATUDPTemplate.txt was replaced successfully
11:40:52: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7970 IPMAAssistantPhoneBATTemplate.txt"
11:40:52: Backing up C:\Program Files\Cisco\MA\inputBAT\7970 IPMAAssistantPhoneBATTemplate.txt
11:40:52: Copying 7970 IPMAAssistantPhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:52: Verifying C:\Program Files\Cisco\MA\inputBAT\7970 IPMAAssistantPhoneBATTemplate.txt
11:40:52: C:\Program Files\Cisco\MA\inputBAT\7970 IPMAAssistantPhoneBATTemplate.txt was replaced successfully
11:40:52: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7970 IPMAEveryonePhoneBATTemplate.txt"
11:40:52: Backing up C:\Program Files\Cisco\MA\inputBAT\7970 IPMAEveryonePhoneBATTemplate.txt
11:40:52: Copying 7970 IPMAEveryonePhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:52: Verifying C:\Program Files\Cisco\MA\inputBAT\7970 IPMAEveryonePhoneBATTemplate.txt
11:40:52: C:\Program Files\Cisco\MA\inputBAT\7970 IPMAEveryonePhoneBATTemplate.txt was replaced successfully
11:40:52: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7970 IPMAManagerPhoneBATTemplate.txt"
11:40:53: Backing up C:\Program Files\Cisco\MA\inputBAT\7970 IPMAManagerPhoneBATTemplate.txt
11:40:53: Copying 7970 IPMAManagerPhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:53: Verifying C:\Program Files\Cisco\MA\inputBAT\7970 IPMAManagerPhoneBATTemplate.txt
11:40:53: C:\Program Files\Cisco\MA\inputBAT\7970 IPMAManagerPhoneBATTemplate.txt was replaced successfully
11:40:53: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\7970 IPMAManagerPhoneBATUDPTemplate.txt"
11:40:53: Backing up C:\Program Files\Cisco\MA\inputBAT\7970 IPMAManagerPhoneBATUDPTemplate.txt
11:40:53: Copying 7970 IPMAManagerPhoneBATUDPTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:53: Verifying C:\Program Files\Cisco\MA\inputBAT\7970 IPMAManagerPhoneBATUDPTemplate.txt
11:40:53: C:\Program Files\Cisco\MA\inputBAT\7970 IPMAManagerPhoneBATUDPTemplate.txt was replaced successfully
11:40:53: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\IPMAAssistantPhoneBATTemplate.txt"
11:40:53: Backing up C:\Program Files\Cisco\MA\inputBAT\IPMAAssistantPhoneBATTemplate.txt
11:40:53: Copying IPMAAssistantPhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:53: Verifying C:\Program Files\Cisco\MA\inputBAT\IPMAAssistantPhoneBATTemplate.txt
11:40:53: C:\Program Files\Cisco\MA\inputBAT\IPMAAssistantPhoneBATTemplate.txt was replaced successfully
11:40:53: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\IPMAEveryonePhoneBATTemplate.txt"
11:40:53: Backing up C:\Program Files\Cisco\MA\inputBAT\IPMAEveryonePhoneBATTemplate.txt
11:40:54: Copying IPMAEveryonePhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:54: Verifying C:\Program Files\Cisco\MA\inputBAT\IPMAEveryonePhoneBATTemplate.txt
11:40:54: C:\Program Files\Cisco\MA\inputBAT\IPMAEveryonePhoneBATTemplate.txt was replaced successfully
11:40:54: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\IPMAManagerPhoneBATTemplate.txt"
11:40:54: Backing up C:\Program Files\Cisco\MA\inputBAT\IPMAManagerPhoneBATTemplate.txt
11:40:54: Copying IPMAManagerPhoneBATTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:54: Verifying C:\Program Files\Cisco\MA\inputBAT\IPMAManagerPhoneBATTemplate.txt
11:40:54: C:\Program Files\Cisco\MA\inputBAT\IPMAManagerPhoneBATTemplate.txt was replaced successfully
11:40:54: Resetting File Attributes on file "C:\Program Files\Cisco\MA\inputBAT\IPMAManagerPhoneBATUDPTemplate.txt"
11:40:54: Backing up C:\Program Files\Cisco\MA\inputBAT\IPMAManagerPhoneBATUDPTemplate.txt
11:40:54: Copying IPMAManagerPhoneBATUDPTemplate.txt to C:\Program Files\Cisco\MA\inputBAT
11:40:54: Verifying C:\Program Files\Cisco\MA\inputBAT\IPMAManagerPhoneBATUDPTemplate.txt
11:40:54: C:\Program Files\Cisco\MA\inputBAT\IPMAManagerPhoneBATUDPTemplate.txt was replaced successfully
11:40:54: Resetting File Attributes on file "C:\CiscoWebs\Admin\Includes\DBLEnums.js"
11:40:54: Backing up C:\CiscoWebs\Admin\Includes\DBLEnums.js
11:40:54: Copying DBLEnums.js to C:\CiscoWebs\Admin\Includes
11:40:54: Verifying C:\CiscoWebs\Admin\Includes\DBLEnums.js
11:40:55: C:\CiscoWebs\Admin\Includes\DBLEnums.js was replaced successfully
11:40:55: Resetting File Attributes on file "C:\CiscoWebs\Admin\Includes\DBLEnums.asp"
11:40:55: Backing up C:\CiscoWebs\Admin\Includes\DBLEnums.asp
11:40:55: Copying DBLEnums.asp to C:\CiscoWebs\Admin\Includes
11:40:55: Verifying C:\CiscoWebs\Admin\Includes\DBLEnums.asp
11:40:55: C:\CiscoWebs\Admin\Includes\DBLEnums.asp was replaced successfully
11:40:55: Copying SoapSrv.dll to C:\CiscoWebs\API\AXL\V1
11:40:55: Verifying C:\CiscoWebs\API\AXL\V1\SoapSrv.dll
11:40:56: C:\CiscoWebs\API\AXL\V1\SoapSrv.dll was replaced successfully
11:40:56: Resetting File Attributes on file "C:\CiscoWebs\API\AXL\V1\SOAPISAPI.dll"
11:40:56: Backing up C:\CiscoWebs\API\AXL\V1\SOAPISAPI.dll
11:40:56: Copying SOAPISAPI.dll to C:\CiscoWebs\API\AXL\V1
11:40:56: Verifying C:\CiscoWebs\API\AXL\V1\SOAPISAPI.dll
11:40:57: C:\CiscoWebs\API\AXL\V1\SOAPISAPI.dll was replaced successfully
11:40:57: Resetting File Attributes on file "C:\CiscoWebs\API\AXL\V1\AXLEnums.xsd"
11:40:57: Backing up C:\CiscoWebs\API\AXL\V1\AXLEnums.xsd
11:40:57: Copying AXLEnums.xsd to C:\CiscoWebs\API\AXL\V1
11:40:57: Verifying C:\CiscoWebs\API\AXL\V1\AXLEnums.xsd
11:40:57: C:\CiscoWebs\API\AXL\V1\AXLEnums.xsd was replaced successfully
11:40:57: Resetting File Attributes on file "c:\CiscoWebs\AST\ASTIsapi.dll"
11:40:57: Backing up c:\CiscoWebs\AST\ASTIsapi.dll
11:40:57: Copying ASTIsapi.dll to c:\CiscoWebs\AST
11:40:57: Verifying c:\CiscoWebs\AST\ASTIsapi.dll
11:40:57: c:\CiscoWebs\AST\ASTIsapi.dll was replaced successfully
11:40:57: Resetting File Attributes on file "C:\CiscoWebs\CCN\Gateway\silx.dll"
11:40:57: Backing up C:\CiscoWebs\CCN\Gateway\silx.dll
11:40:58: Copying silx.dll to C:\CiscoWebs\CCN\Gateway
11:40:58: Verifying C:\CiscoWebs\CCN\Gateway\silx.dll
11:40:58: C:\CiscoWebs\CCN\Gateway\silx.dll was replaced successfully
11:40:58: Resetting File Attributes on file "C:\CiscoWebs\Soap\astsvc.dll"
11:40:58: Backing up C:\CiscoWebs\Soap\astsvc.dll
11:40:58: Copying astsvc.dll to C:\CiscoWebs\Soap
11:40:58: Verifying C:\CiscoWebs\Soap\astsvc.dll
11:40:59: C:\CiscoWebs\Soap\astsvc.dll was replaced successfully
11:40:59: Resetting File Attributes on file "C:\DCDSrvr\Lib\UMX.dll"
11:40:59: Backing up C:\DCDSrvr\Lib\UMX.dll
11:40:59: Copying UMX.dll to C:\DCDSrvr\Lib
11:40:59: Verifying C:\DCDSrvr\Lib\UMX.dll
11:40:59: C:\DCDSrvr\Lib\UMX.dll was replaced successfully
11:40:59: Resetting File Attributes on file "C:\DCDSrvr\Lib\UMProviders.dll"
11:40:59: Backing up C:\DCDSrvr\Lib\UMProviders.dll
11:41:00: Copying UMProviders.dll to C:\DCDSrvr\Lib
11:41:00: Verifying C:\DCDSrvr\Lib\UMProviders.dll
11:41:00: C:\DCDSrvr\Lib\UMProviders.dll was replaced successfully
11:41:00: Resetting File Attributes on file "C:\DCDSrvr\Lib\UMAuthentication.dll"
11:41:00: Backing up C:\DCDSrvr\Lib\UMAuthentication.dll
11:41:00: Copying UMAuthentication.dll to C:\DCDSrvr\Lib
11:41:00: Verifying C:\DCDSrvr\Lib\UMAuthentication.dll
11:41:00: C:\DCDSrvr\Lib\UMAuthentication.dll was replaced successfully
11:41:00: Resetting File Attributes on file "C:\DCDSrvr\Lib\UMAccessDll.dll"
11:41:00: Backing up C:\DCDSrvr\Lib\UMAccessDll.dll
11:41:00: Copying UMAccessDll.dll to C:\DCDSrvr\Lib
11:41:00: Verifying C:\DCDSrvr\Lib\UMAccessDll.dll
11:41:01: C:\DCDSrvr\Lib\UMAccessDll.dll was replaced successfully
11:41:01: Resetting File Attributes on file "C:\DCDSrvr\Lib\UMEncryption.dll"
11:41:01: Backing up C:\DCDSrvr\Lib\UMEncryption.dll
11:41:01: Copying UMEncryption.dll to C:\DCDSrvr\Lib
11:41:01: Verifying C:\DCDSrvr\Lib\UMEncryption.dll
11:41:01: C:\DCDSrvr\Lib\UMEncryption.dll was replaced successfully
11:41:01: Resetting File Attributes on file "C:\Program Files\Cisco\WebKnight\WebKnight.xml"
11:41:01: Backing up C:\Program Files\Cisco\WebKnight\WebKnight.xml
11:41:01: Copying WebKnight.xml to C:\Program Files\Cisco\WebKnight
11:41:01: Verifying C:\Program Files\Cisco\WebKnight\WebKnight.xml
11:41:02: C:\Program Files\Cisco\WebKnight\WebKnight.xml was replaced successfully
11:41:02: Resetting File Attributes on file "C:\CiscoWebs\Admin\_RemoteScripts\rs_phone.asp"
11:41:02: Backing up C:\CiscoWebs\Admin\_RemoteScripts\rs_phone.asp
11:41:02: Copying rs_phone.asp to C:\CiscoWebs\Admin\_RemoteScripts
11:41:02: Verifying C:\CiscoWebs\Admin\_RemoteScripts\rs_phone.asp
11:41:02: C:\CiscoWebs\Admin\_RemoteScripts\rs_phone.asp was replaced successfully
11:41:02: Resetting File Attributes on file "C:\CiscoWebs\Admin\_RemoteScripts\rs_routegroup.asp"
11:41:02: Backing up C:\CiscoWebs\Admin\_RemoteScripts\rs_routegroup.asp
11:41:02: Copying rs_routegroup.asp to C:\CiscoWebs\Admin\_RemoteScripts
11:41:02: Verifying C:\CiscoWebs\Admin\_RemoteScripts\rs_routegroup.asp
11:41:02: C:\CiscoWebs\Admin\_RemoteScripts\rs_routegroup.asp was replaced successfully
11:41:02: Resetting File Attributes on file "C:\Inetpub\wwwroot\Help\wwhelp\wwhimpl\js\scripts\search.js"
11:41:02: Backing up C:\Inetpub\wwwroot\Help\wwhelp\wwhimpl\js\scripts\search.js
11:41:03: Copying search.js to C:\Inetpub\wwwroot\Help\wwhelp\wwhimpl\js\scripts
11:41:03: Verifying C:\Inetpub\wwwroot\Help\wwhelp\wwhimpl\js\scripts\search.js
11:41:03: C:\Inetpub\wwwroot\Help\wwhelp\wwhimpl\js\scripts\search.js was replaced successfully
11:41:03: Resetting File Attributes on file "C:\CiscoWebs\Admin\_RemoteScripts\rs_numplan.asp"
11:41:03: Backing up C:\CiscoWebs\Admin\_RemoteScripts\rs_numplan.asp
11:41:03: Copying rs_numplan.asp to C:\CiscoWebs\Admin\_RemoteScripts
11:41:03: Verifying C:\CiscoWebs\Admin\_RemoteScripts\rs_numplan.asp
11:41:03: C:\CiscoWebs\Admin\_RemoteScripts\rs_numplan.asp was replaced successfully
11:41:03: Resetting File Attributes on file "C:\Program Files\Cisco\WebKnight\WebKnight.dll"
11:41:03: Backing up C:\Program Files\Cisco\WebKnight\WebKnight.dll
11:41:03: Copying WebKnight.dll to C:\Program Files\Cisco\WebKnight
11:41:03: Verifying C:\Program Files\Cisco\WebKnight\WebKnight.dll
11:41:03: C:\Program Files\Cisco\WebKnight\WebKnight.dll was replaced successfully
11:41:03: Resetting File Attributes on file "\CiscoWebs\Admin\Includes\xmlruleprocess.asp"
11:41:04: Backing up \CiscoWebs\Admin\Includes\xmlruleprocess.asp
11:41:04: Copying xmlruleprocess.asp to \CiscoWebs\Admin\Includes
11:41:04: Verifying \CiscoWebs\Admin\Includes\xmlruleprocess.asp
11:41:04: \CiscoWebs\Admin\Includes\xmlruleprocess.asp was replaced successfully
11:41:04: Resetting File Attributes on file "\CiscoWebs\Admin\Includes\xmlrulevalid.js"
11:41:04: Backing up \CiscoWebs\Admin\Includes\xmlrulevalid.js
11:41:04: Copying xmlrulevalid.js to \CiscoWebs\Admin\Includes
11:41:04: Verifying \CiscoWebs\Admin\Includes\xmlrulevalid.js
11:41:04: \CiscoWebs\Admin\Includes\xmlrulevalid.js was replaced successfully
11:41:05: Resetting File Attributes on file "C:\Program Files\Cisco\MA\MADirectory.dll"
11:41:05: Backing up C:\Program Files\Cisco\MA\MADirectory.dll
11:41:05: Copying MADirectory.dll to C:\Program Files\Cisco\MA
11:41:05: Verifying C:\Program Files\Cisco\MA\MADirectory.dll
11:41:05: C:\Program Files\Cisco\MA\MADirectory.dll was replaced successfully
11:41:06: Running ctftpPerfmon.exe
11:41:07: ctftpPerfmon.exe reports Success Returned Value was 0- 11:41:07
11:41:09: Running cmd.exe /c "c:\program files\cisco\bin\QRTFileMgr.exe" -UnregServer
11:41:10: cmd.exe /c "c:\program files\cisco\bin\QRTFileMgr.exe" -UnregServer reports Success Returned Value was 0- 11:41:10
11:41:12: Running xcopy.exe "c:\program files\cisco\bin\perfport.dll" "c:\ciscowebs\soap\*.*" /R /Y
11:41:13:   xcopy.exe "c:\program files\cisco\bin\perfport.dll"   "c:\ciscowebs\soap\*.*" /R /Y reports Success Returned Value was 0-   11:41:13
11:41:15: Running xcopy.exe "c:\program files\cisco\bin\risport.dll" "c:\ciscowebs\soap\*.*" /R /Y
11:41:15:  xcopy.exe "c:\program files\cisco\bin\risport.dll"   "c:\ciscowebs\soap\*.*" /R /Y reports Success Returned Value was 0-   11:41:15
11:41:18: Running cmd.exe /c "c:\program files\cisco\bin\QRTFileMgr.exe" -RegServer
11:41:18: cmd.exe /c "c:\program files\cisco\bin\QRTFileMgr.exe" -RegServer reports Success Returned Value was 0- 11:41:18
11:41:20: Running cmd.exe /c regsvr32.exe /s "C:\dcdsrvr\lib\CiscoPWDChanger.dll"
11:41:21: cmd.exe /c regsvr32.exe /s "C:\dcdsrvr\lib\CiscoPWDChanger.dll" reports Success Returned Value was 0- 11:41:21
11:41:23: Running Expand-ma-war.exe
11:41:28: Expand-ma-war.exe reports Success Returned Value was 0- 11:41:28
11:41:31: Running jarhead.exe
11:41:31: JARHandler successful
11:41:31: jarhead.exe reports Success Returned Value was 0- 11:41:31
11:41:34: Running ccmperfmon.exe
11:41:35: ccmperfmon.exe reports Success Returned Value was 0- 11:41:35
11:41:37: Running ciscocm-2007-JRE-DST-Update.1-0-1.exe -s -a -s
11:41:47: ciscocm-2007-JRE-DST-Update.1-0-1.exe -s -a -s reports Success Returned Value was 0- 11:41:47
11:41:50: Running CSCsg31090.exe2011-11-21 11:41:50 :
Performing resolution for CSCsg31090
2011-11-21 11:41:50 : "AccessSSLFlags" state set for Server Plugins?: False
2011-11-21 11:41:50 : SSL needs turned off for Server Plugins
2011-11-21 11:41:50 : SSL was successully turned off for Server Plugins
2011-11-21 11:41:50 : "AccessSSLFlags" state set for Client Plugins?: False
2011-11-21 11:41:50 : SSL needs turned off for Client Plugins
2011-11-21 11:41:50 : SSL was successully turned off for Client Plugins
11:41:51: CSCsg31090.exe reports Success Returned Value was 0- 11:41:51
11:41:53: ****************************************************
11:41:53: Database update begun:  11:41:53
11:43:11: Database update 1 successfully completed:  11:43:11
11:43:11: ****************************************************
11:43:12: Database update 2 successfully completed:  11:43:12
11:43:12: ****************************************************
11:43:12: System Version update begun:  11:43:12
11:43:13: System Version update successfully completed:  11:43:13
11:43:13: ****************************************************
11:43:13: Component Version update begun:  11:43:13
11:43:14: Component Version update successfully completed:  11:43:14
11:43:14: ****************************************************
11:43:14: Writing variables to C:\esbackout\es.ini
11:43:14: Creating Uninstall Link Add/Remove Programs
11:43:14: Replication Status is At least one agent-implementing job has failed to execute successfully
11:43:14:   End of Installation Replication check Failed  with the status reported  as At least one agent-implementing job has  failed to execute  successfully.  Please fix replication issues before  continuing  installation.
11:43:14: ********************************************************************************************************
11:43:14: Listing of Errors:
11:43:14: Unless otherwise indicated, these errors are non-critical in nature
11:43:14: ******** ERROR - Embedded Device Package installation reported an error
11:43:14:   Possible Critical Error - SQL Replication Status at end of  Installation  was reported as At least one agent-implementing job has  failed to  execute successfully.  Please fix replication issues before  continuing  installation.
11:43:14:
11:43:14:   Dumping current process list to "C:\Program Files\Common   Files\Cisco\Logs\CCMPatch\Cisco Unified CallManager 4.2(3)sr2b   Installation 2011-11-21 11.29.log.Process List.log"
11:43:14: Install completed 2011-11-21     11:43:14
11:43:14: ******  2 Errors Detected  ****
11:43:14: [Install of Cisco Unified CallManager 4.2(3)sr2b]
11:43:14: Installer Version: 3.60.06
11:43:14: Build ID: 0022010
Any help would be greatly appreciated!
Everyone's tags (4)
1 ACCEPTED SOLUTION
Green
Cisco IP phone 7942 support in CCM 4.2(3)
According to the data sheet
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/phones/ps379/ps8535/product_data_sheet0900aecd8069bb68.html
Supported in Cisco Unified Communications Manager Versions 4.1(3)sr5b, 4.2(3)sr2b, 4.3(1), 5.1.1(b), 5.1(2), 6.0(1) and greater
You cound try applying DEV PACK 60
ciscocm.4-2-3-DevPack-60.exe
README = http://www.cisco.com/web/software/282074299/26745/ciscocm.4-2-3-DevPack-60_readme.html#_Toc185234011
Alex
Regards, Alex. Please rate useful posts.
Green
Alex
Thanks for your response. That is correct, and I ran the patch, but not the devpack yet. I read somewhere that the devpac will only provide the firmware for the phone however, the original patch should place 7942 on the list.
Any other ideas?
Green
I can only suggest that you upgrade to
ciscocm.4-2-3-sr4b.exe
This is the latest patch for 4.2.3
Alex
Yes, I was contemplating doing that. I'm going to install the devpack first and see if that does any good. If not, I will try installing the latest patch. Thanks for your help.
I just wanted to let you know that I ran the devpack file and that resovled the issue. I can now see 7942 as well as 7945 phones. I have yet to register a phone and test if it will download the appropriate firmware, but while the devpack was installing, I saw a message that read something to the extent of: "Installing firmware files," so I'm guessing they should be installed as well. Thanks for your help.
Asad
877
