Cisco ip phone 7942G
I have a problem with three cisco IP phone 7942G,  their screen doesn't appear correctly. We see split images in the screen. I think it is a hardware problem.
Can you confirm?
Aristide
Set everything to default.
Screen sill look bad?
FActory reset the phone...
1) Power off the phone
2) Hold down the '#'.
3) While holding '#', connect an AC adaptor to the phone.
4) Continue to hold '#' until the line buttons blink amber.
5) Release the '#' key.
6) 123456789*0#
7) The lights should change color from amber to red. The phone is now
resetting to factory defaults.
If you still have the problem you have a hardware issue for sure.
Please Kudos/rate if this help!
Thank you Jose,
I will Back to you
Hall of Fame Super Silver
Are these new phones? If so, this may be due to the recent hardware change where the phones need to be on version 9.3.1SR1 or newer.
Chris
145
