cisco ip phone 7961 not ringing
Hi guys,
It appears I have a problem with my telephone device as calls are received however it is not ringing with a sound. The dnd button is not enabled.  Any ideas?
Thank you
Does the call appear on
Does the call appear on phone display?
Yes, and its flashing in red
Yes, and its flashing in red so I can know that someone is ringing
could you please search that
could you please search that extension number under route plan report to verify whether it is assigned to some other device also?
Please ensure the ringer volume is set to audible level.
if you assign any other extension to this device, will it ring? if not, most probably it could be phone hardware issue
//Suresh Please rate all the useful posts.
Hi.Assuming you are using
Hi.
Assuming you are using CUCM 8.5 or later, check under line configuration "Ring Setting (phone idle) value. try to force it to "ring"
Carlo
Please rate all helpful posts "The more you help the more you learn"
47
