Cisco IP Phone 7961
Hi, How many maximum number of calls can be presented on cisco 7961 phone on particular line on Call manager 5.X.In line configuration under call manager it says maximum of 200 calls,but to achieve this does phone needs to have specific hardware/software requirments
1 REPLY
Anonymous
N/A
Re: Cisco IP Phone 7961
You can configure a maximum of 200 calls for a line on a device. The limiting factor is the total number of calls that are configured on the device. As you configure the number of calls for one line, the calls that are available for another line decrease. The default specifies four. If the phone does not allow multiple calls for each line, the default specifies two.
458
