cisco ip phone 7962G with cisco callmanager ver 6.0.1.2000-4
Dear all
i have cisco callmanager ver 6.0.1.2000-4 which dosen't support cisco ip phone 7962G in its phone adding list so how could i add it as sip third party ?
so can anyone help me with that please.
Thank You.
Best Regards.
Mohammad Hamed
Network system Engineer
Mob: +2- 0108745878
Email : eng.m.hamed@hotmail.com
Have you already tried installing the latest devpack for you release??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
According to
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8536/product_data_sheet0900aecd8069bd41.html it is supported on 6.0.1, so you may just need a devicepack.
GTG
Please rate all helpful posts.
Hall of Fame Super Red
Re: cisco ip phone 7962G with cisco callmanager ver 6.0.1.2000-4
Hi Mohamed,
Java is most correct here (+5 Java-Man! )
If you install cmterm-devicepack6.0.1.3129-1.cop.sgn you will add the
ability to configure/add the 7962 IP phone.
Cisco Unified CallManager Device Package 6.0.1 (3129-1)
http://www.cisco.com/web/software/282074299/31138/cmterm-devicepack-6_0_1_3129-1_readme.html
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
PS: +5 to Gordon as well! Happy Holidays to you
Hi Rob,
thanks for your reply
i have download this file
cmterm-devicepack6.0.1.3129-1.cop.sgn and tried to install it at the callmanager and after the the callmanager download the file i got the following  attatched error at the download status of callmanager
so could this because this file i.e could try anather file ?
look attatch below
thanks
Hi Mohamed,
Did you run the file through an MD5 checker after downloading to ensure
it matches this MD5 hash
95:5f:2f:92:57:1e:8a:9e:8b:b2:9d:fc:50:6f:61:6b
I would try downloading it again and checking the hash before proceeding
Cheers!
Rob
Hi Rob,
yes i have checked the file after downloading using MD5 tool and it mathes this hash correctly
thanks
Hi Mohamed,
Just curious, are using a DVD or SFTP? Usually the directory
location is a forward slash "/" not a backward slash "\" as shown
in the screenshot you linked earlier.
Cheers!
Rob
Hi Rob,
i am using SFTP remote and finally it works but i tried anather version of devicepack
now i could add register my 7962 phone.
i would like to thank you for your great support
and thank you all.
Best Regards.
Mohammad Hamed
Mob: +2- 0108745878
553
