cisco ip phone 7985 setup
dear sir,
please advise how to setup and test the the above mentioned phone? We've ccm 4.1(3) sr2, 1 pub and 1 sub.
Please advise the steps.
thanks.
1 REPLY
Silver
Re: cisco ip phone 7985 setup
You can automatically add phones to the Cisco CallManager database by using auto-registration or manually add phones by using the Phone Configuration windows.
By enabling auto-registration, you can automatically add a Cisco IP Phone to the Cisco CallManager database when you connect the phone to your IP telephony network. During auto-registration, Cisco CallManager assigns the next available sequential directory number to the phone. In many cases, you might not want to use auto-registration; for example, if you want to assign a specific directory number to a phone.
If you do not use auto-registration, you must manually add phones to the Cisco CallManager database.
After you add a Cisco IP Phone to Cisco CallManager Administration, the RIS Data Collector service displays the device name, registration status, and the IP address of the Cisco CallManager to which the phone is registered in the Phone Configuration window.
This URL should help you:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008037eb1c.html
265
