Cisco IP Phone Display
Dear networkers,
We have installed Cisco Unfied Communications Manager 6. Every thing is OK with the install and config.
I have a quick question: Can we change the "your current Options" in the IP Phone screen to another phrase such as for exemple the Enterprise Name or stgh like that?
Best Regards.
PS: We are using Cisco 7911, 7941 and 7970.
Thanks in advance.
Re: Cisco IP Phone Display
I dont think u can change that text
But u can change the background to ur custom image
You cannot change that message
java
if this helps, please rate
java
www.cisco.com/go/pdi
176
