Cisco IP Phone Firmware upgrade
I have the following files on my router's flash.
apps42.8-4-1-23.sbn
cnu42.8-4-1-23.sbn
cvm42sccp.8-4-1-23.sbn
dsp42.8-4-1-23.sbn
jar42sccp.8-4-1-23.sbn
SCCP42.8-4-2S.loads
term42.default.loads
term62.default.loads
and
apps42.9-1-1TH1-16.sbn
cnu42.9-1-1TH1-16.sbn
cvm42sccp.9-1-1TH1-16.sbn
dsp42.9-1-1TH1-16.sbn
jar42sccp.9-1-1TH1-16.sbn
SCCP42.9-1-1SR1S.loads
How can i make sue that cisco ip phone 7962 phones take latest firmware which is 42.9. Right now they have 42.8 firmware?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Omer,
The phone firmware is specified in Step # 5 below;
SUMMARY STEPS
1. enable
2. configure terminal
3. tftp-server device:firmware-file
4. telephony-service
5. load phone-type firmware-file
6. create cnf-files
7. end
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html#wp1070512
Cheers!
Rob
Hi Omer,
SUMMARY STEPS
1. enable
6. create cnf-files
7. end
Cheers!
Rob
So, i have 6 different files in my flash. I have to give tftp-server command 6 time and then load command 6 time???
That is correct,  You will have a entry per firmware file.
HTH,
Justin
i am getting the following error. When i am putting command
Router-CME(config-telephony)#load 7962 dsp42.9-1-1TH1-16.sbn
LOAD COMMAND ERROR:cnf-file location system is not supported for creating automatic tftp bindings. Please use file location flash | slot0 | tftp OR create tftp bindings manually
Re: Cisco IP Phone Firmware upgrade
Here is an example for a 7975 phone.
tftp-server flash:/PHONES/7975/apps75.8-5-3TH1-6.sbn alias apps75.8-5-3TH1-6.sbn
tftp-server flash:/PHONES/7975/cnu75.8-5-3TH1-6.sbn alias cnu75.8-5-3TH1-6.sbn
tftp-server flash:/PHONES/7975/cvm75sccp.8-5-3TH1-6.sbn alias cvm75sccp.8-5-3TH1-6.sbn
tftp-server flash:/PHONES/7975/dsp75.8-5-3TH1-6.sbn alias dsp75.8-5-3TH1-6.sbn
tftp-server flash:/PHONES/7975/jar75sccp.8-5-3TH1-6.sbn alias jar75sccp.8-5-3TH1-6.sbn
tftp-server flash:/PHONES/7975/SCCP75.8-5-3S.loads alias SCCP75.8-5-3S.loads
tftp-server flash:/PHONES/7975/term75.default.loads alias term75.default.loads
Telephony-Service
load 7975 SCCP75.8-5-3S
HTH,
Justin
Same error
Router-CME(config-telephony)#load 7962 SCCP42.9-1-1SR1S
Updating CNF files
CNF files update complete for phonetype(7962)
1. configure max-dn, max-ephone
2. configure time (clock set or ntp)
3. ip source-add port
4. load and create cnf
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_configuration_examples_list.html
I am getting the error but it worked for me. Thanks ROB and all.
Can i repeat the same process for cisco 7911 too? Or it works for only one phone model.
Telephony-Service
and same time i do for Cisco 7911
5924
