Cisco IP Phone Power Save Settings
Dear,
Is it possible to change "Display Idle Timeout", "Display On Time", "Display On Duration", "Display Idle Timeout" in CCM for all the phones?
I know this can be done indivially from CCM-> Phone Configuration but what if you have hunderds of phones, I would like to select all phones in the pool and change once instead of going one by one for all phones.
Thank you,
1 REPLY
Gold
Re: Cisco IP Phone Power Save Settings
Currently there is no menu option to get this done. To change the setting on a clusterwide basis, manually modify the file IP
Phones Rules.xml file located at:
C:\Program Files\Cisco\Bin\Xmltemp\XML
Within the xml file, scroll almost to the bottom and look for the lines that
contain "displayOnTime", "displayOnDuration", and "displayIdleTimeout".
Modify the value contained in the xx:xx to the
desired settings.
345
