Community Member
Cisco ip phone "how to change language"
    Hi .
Ineed to install Arabic Language in the phones.Any help will be higly appreciated.
Everyone's tags (4)
Callmanager version that you are currently running if you can let us know that would be helpful to point you in the correct direction.
BTW for languages you need to isntall locales
For Arabic language you need to use custom locals. Its not predefined system local by Cisco. I wrote a blog on how to change language but didn't include Arabic lanugage. I am sharing the link incase it can help.
http://x-ccie.blogspot.com/2012/04/cme-localization-support.html
Please rate the post if you find it helpful.
Community Member
Callmanager ver 8.6!
Hall of Fame Super Silver
Hall of Fame Super Red
Hi Shaikh,
Here's the path to find the locale;
Unified Communications Manager/CallManager Locale Installer-8.6(2.1000-1)
or if you are @ CUCM 8.6(1)
Unified Communications Manager/CallManager Locale Installer-8.6(1.1000-1)
The install process is shown here;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/8_6_1/cucos/iptpch7.html
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Community Member
Thankyou every one! .. what is the procedure if i want to use it for voicemail ..i have cisco unity connection 8.6 as well ?
Adding or Removing Cisco Unity Connection  8.x Languages
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrug027.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Keep in mind that with Unity Connection you need to put exact compatible version of locale, where is CUCM the locale is compatible with multiple CUCM versions, for UCON they usualy work only one one specific version and each ES/SU/etc requires different locale files, and some versions may not have any locales available.
So, make sure you read the ReadMe files before you apply them.
Chris
Hi Shaikh,
There are different 8.6.2 locales depending on the exact version
of Unity Connection you are running;
Installing Additional Cisco Unity Connection Languages
Revised April 25, 2012
NoteAll  locales other than ENU are released for Connection 8.6(2) Engineering  Special 12. Connection 8.6(2) ES 12 locales are supported only with  Connection 8.6(2) ES 12.
All  locales other than ENU are released for Connection 8.6(2) SU 1 (ES 25).  For more information on the supported engineering-special versions with  these locales, please contact Cisco Technical Assistance Center (TAC).
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/release/notes/862cucrn.html#wp1300703
If you are running Unity Connection 8.6(1) here are the related notes;
Revised March 06, 2012
Note Connection  8.6 versions of languages other than ENU are released. The Connection  server must be running a minimum of 8.6(1)ES2 to use these languages.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/release/notes/861cucrn.html#wp1300703
Cheers!
Rob
10680
