01-06-2014 09:59 PM - edited 03-16-2019 09:07 PM
Hello Folks,
Today, received an issue from one of our customer that in their Cisco IP Phone the mute button always indication "Red".. When they do mute on and off
We see it shows "Microphone mute on" and "Microphone mute off", but the red indication remains same.
Can you please let me know if you have any suggestion to resolve this issue. I have happy to give you any logs you may require.
We tried "Factory reset" and its with the latest firmware, i don't see any config mismatch on CUCM.
Raja...
01-06-2014 10:42 PM
What is the phone model, cucm version, phone firmware version?
Is it affecting all the phones of the same model / type or a few only?
Manish
01-06-2014 10:46 PM
Hello Manish,
Thank you for looking into this issue.
Here are the details.
Phone Model : Cisco 7942
Phone firmware :SCCP42.9-3-1SR2-1S
CUCM Version : 8.5.1.16102-1
If affects a single phone on my cluster...
01-06-2014 11:15 PM
Hi Raja,
Thanks for the details. Have you tried booting up the phone without any headset / expansion module connected to it? If the issue comes up even after a normal phone boot up without any additional devices connected to it and you have already tried a factory reset , it could be a phone issue. The only other thing i could suggest is to try and register it to a diff server or cluster ( like a lab setup ) if possible. If the issue folows the phone then we would be sure that the phone is faulty.
Manish
01-06-2014 11:19 PM
Yes, i tried registering the phone in another subscriber of my cluster, the issue remains same.
We don't have any expansion module connected... Do we have any specific setting on either Device or line page for the mute button control ?
Thanks.
01-06-2014 11:23 PM
There is no setting for mute button on CUCM page. Infact pressing mute and unmute is not even captured in cucm traces. I would suggest trying it on a diff cluster if possible to confirm the issue.
Manish
01-06-2014 11:30 PM
Thank you for the useful information.
Yes, just i see the below traces when i perform mute and unmute on phone.
Line 6360: 04:17:52.819 |StationInit: (0053120) StationMediaPathEvt Speaker (3) = On (1)|3,100,50,1.998263047^19.237.146.83^SEP002699444E98
Line 6361: 04:17:52.827 |StationInit: (0053120) OffHook.|3,100,50,1.998263048^19.237.146.83^SEP002699444E98
Line 13307: 04:18:48.767 |StationInit: (0053120) SoftKeyEvent softKeyEvent=9(EndCall) lineInstance=1 callReference=55149225.|3,100,50,1.998269420^19.237.146.83^SEP002699444E98
So... Can we come to the conclusion that it has a faulty hardware. ??? Mr. Manish
Thanks.
01-06-2014 11:44 PM
Mr Raja,
It looks like this is the message for setting the phone to speakerphone mode. The other two StationInit messages are clearly for Endcall and phone going offhook so they are not related.
Manish
01-06-2014 11:47 PM
Yes, you are right but i performed the way as below.
1. Pressed the "Speaker" button.
2. Pressed the "Mute" button
3. Pressed the softkey "Endcall"
So as you said, the Mute event did not register there...
Thanks.
