01-07-2012 08:40 AM - edited 03-16-2019 08:51 AM
i have customer having Nortel switches 5520 with Nortel IP phones. The customer is having Nortel NSNA used to provide security for the network. For Nortel IP phones the customer is using signatues (ex. Nortel-i2004-A)
We are planning to replace Nortel IP phones with Cico ones (7911, 7942 and 9971) but we need to keep the security setup the customer is having. In order to do that it is required to have Cisco IP phones signatures
any information please
regards,
Ibrahim Chehouri
01-07-2012 08:49 AM
And what a signature would be, exactly ?
01-07-2012 09:18 AM
a signature is like a pattern that can define a specific type of device. For example when you define "Nortel-i2004-A" in NSNA then it will bypass the security checking for Nortel phone type 2004. If not defining such signature then it will have same checking as PC (which include antivirus and other stuff)
regards,
Ibrahim
01-07-2012 09:23 AM
I think you have to ask this to Nortel. You are not talking anything standard, and I don't think that Cisco has to provide non-standard specifications to facilitate third-party security solutions.
