Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Ip Phone
msobhnani
Whenever one voice message came i have to put the password to read the message in cisco ip phone, I already reseted the password & pin of the IP phone along with the copy of configuration of another Cisco ip Phone in which no voice mailbox password is there successfully configured  still the problem is there i have to press # to continue the voice mailbox message.Please guide me how to resolve this issue.
Mukesh
ronpatel
Level 8
Level 8
Hi Mukesh
I consider you are using CUC.
Is "  checked or not ?
regards
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
please explain wat you mean by "Skip PIN when calling from a known extension".Its an option in Call Manager software which is to be checked out or what?
yes i understood wat u want to say,let me check & update you the status.
Dont forget to rate the post by clicking the stars below the answers.
Ronak Patel
