CISCO IP Phone
Hi every one,
I have call manger 5 and alot of CISCO IP Phones. All phones work fine by Power over Ethernet PoE
Now, we have a office that is far from the main buliding about 185 m, I making LAN cable from Switch to Phone (about 190 m cable)
when tried to connect the CISCO IP Phone 7911, it gave "configuring IP" and after that gave "Disconnect ethernet"
Can any one tell me what is the problem ? and What is his suggestion to solve this ?
1 REPLY
Re: CISCO IP Phone
Based on the specifications for Ethernet/Fast Ethernet over twisted pair, the commonly accepted maximum distance between an Ethernet transmitter and receiver is 100 meters.  In my experience I have found that if you go much beyond that, you will have issues.  With Fast Ethernet I have seen distances beyond 100 meters but 190 meters would be well outside of what I have seen work.
In your case, you are almost twice that maximum distance.  You need to shorten that distance in some way.  If you are dropping a single phone then placing a local switch wouldn't make much sense.  There is a good thread on this exact topic here:
https://supportforums.cisco.com/message/501805#501805
If you have multiple phones in the location, then you may want to run a single fiber pair and put in a local switch.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
370
