Cisco ISDN network mode
hello
I have one cisco 2801 connected to an Alcatel PBX by one BRI.
My BRI is configured in network mode and I can receive calls from PBX to my 2801 but I can?t make calls from 2801 to PBX.
Here is the configuration:
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn send-alerting
isdn static-tei 0
isdn skipsend-idverify
line-power
any ideas
thanks in advance
Hall of Fame Super Gold
Re: Cisco ISDN network mode
hi carlos,
1st of all you don't need line-power (needed only for unpowered phones) nor send-alerting (is the default). You may or may not need overlap-receiving.
Second, to place calls you need to configure dial-peer that are the basic building blocks for Cisco VoIP. Search for 'dial-peers basic' and you will get a lot of documetns, pick a basic one.
Finally, you enable debug isdn q931 and term monitor, to see what is going one between the PBX and the router.
I just remove the line power, send-alerting and overlap-receiving.
When I Make a call to the PBX, this is the q931
Ind i = 0x8183 - Origination address is non-ISDN
Display i = 'Laura Ruiz'
Calling Party Number i = 0x0080, '4130'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '33902405555'
*Jan 15 09:52:01.964: ISDN BR0/2/0 **ERROR**: CCBRI_Go: NO CCB Src->L3 call id 0
x8002, event 0x95 ces 0
*Jan 15 09:52:01.964: ISDN **ERROR**: Module-CCBRI Function-_Go Error-Event r
eceived for an unrecognized call. Data- 95, 0
*Jan 15 09:52:02.128: ISDN BR0/2/0 Q921: Net RX <- IDREQ ri=7680 ai=127
*Jan 15 09:52:02.128: ISDN BR0/2/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 63 tei 127 ces 0 ev 0x3
*Jan 15 09:52:02.132: ISDN BR0/2/0 SERROR: L2_Go: at bailout DLCB is NULL
L2: sapi 63 tei 127 ces 0 ev 0x650
L2: sap
and when I make a call from the PBX:
*Jan 15 09:51:16.739: ISDN BR0/2/0 SERROR: L2_Go: at bailout DLCB is NULL
*Jan 15 09:51:16.739: ISDN BR0/2/0 Q921: Net TX -> IDDENY ri=6656 ai=127
*Jan 15 09:51:16.739: ISDN BR0/2/0 Q921: Net TX -> UI sapi=63 tei=127
*Jan 15 09:51:16.739: ISDN BR0/2/0 Q921: Net TX -> IDCKRQ ri=0 ai=0
*Jan 15 09:51:18.751: ISDN BR0/2/0 Q921: Net RX <- IDREQ ri=6912 ai=127
*Jan 15 09:51:18.751: ISDN BR0/2/0 SERROR: L2_Go: at bailout DLCB is NULL
*Jan 15 09:51:18.755: ISDN BR0/2/0 SERROR: L2_Go: at bailout DLCB is NULL
*Jan 15 09:51:18.755: ISDN BR0/2/0 Q921: Net TX -> IDDENY ri=6912 ai=127
*Jan 15 09:51:18.755: ISDN BR0/2/0 Q921: Net TX -> UI sapi=63 tei=127
*Jan 15 09:51:18.755: ISDN BR0/2/0 Q921: Net TX -> IDCKRQ ri=0 ai=0
any ideas?
seems like trouble is at L2. Which IOS are using, can you try something like 12.4(9)T ?
Is the PBX using dynamic or static TEI ?
Would you post show isdn status and show interface ?
My IOS is 12.4(4)T1
The sh ISDN STA command:
Global ISDN Switchtype = basic-net3
ISDN BRI0/2/0 interface
******* Network side configuration *******
dsl 4, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 4 CCBs = 0
The Free Channel Mask: 0x80000003
I set in my cisco,
isdn static-tei 0
But I don?t know how alcatel works.
Must I remove that line from my configuration?
thanks
yes, it looks for the IDREQ packet that the switch is set for dynamic TEI.
See:
http://www.cisco.com/warp/public/129/bri-layer2.html
1433
