Community Member
Cisco ISR G2 SIP Calls Capacity
Dear all,
We're planning for Cisco Voice Gateway configuration with SIP trunk, till now no E1s are used.
I would like to know how can we calculate the number of simulataneous calls that a cisco ISR G2 router (1921. 2921.3945,etc...) can support ?
How much sip simultaneous calls each ISR G2 model can support ?
Is it better to use SIP or we must get into E1 PRI ?
1 ACCEPTED SOLUTION
VIP Super Bronze
The Q and A below has the call capacity you are looking for
Table 1. Number of IP-to-IP Calls per Platform
Platform
Maximum Number of Simultaneous Calls (Flow-Through)
Cisco 3945E
2500
Cisco 3925E
2100
Cisco 3945
950
Cisco 3925
800
Cisco 2951
500
Cisco 2921
400
Cisco 2911
200
Cisco 2901
100
Cisco ASR 1004; and Cisco ASR 1006 Router Processor 2 (RP2)
5000; 16000*
Cisco ASR 1002, ASR 1004, and ASR 1006 RP1
1750
Cisco AS5350XM and AS5400XM
600
Cisco 3845
500
Cisco 3825
400
Cisco 2851
225
Cisco 2821
200
Cisco 2811
110
Cisco 2801
55
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps5640/prod_qas09186a00801da69b.html
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Platform
Cisco 3945E
2500
Cisco 3925E
2100
Cisco 3945
950
Cisco 3925
800
Cisco 2951
500
Cisco 2921
400
Cisco 2911
200
Cisco 2901
100
5000; 16000*
1750
600
Cisco 3845
500
Cisco 3825
400
Cisco 2851
225
Cisco 2821
200
Cisco 2811
110
Cisco 2801
55
VIP Super Bronze
Be careful not to make your decision solely based on the maximum concurrent calls. The far lower number is call [setup/teardown] per second. Keep in mind that Mobile Connect will significantly amplify this. Page 15 of the following document shows the details.
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Please remember to rate helpful responses and identify helpful or correct answers.
Community Member
Thanks for the very useful
Thanks for the very useful answer!
2790
