09-09-2014 01:00 PM - edited 03-17-2019 12:05 AM
Dear all,
I configured the Cisco jabber for desktop, iphone and for android.
Problem is that Cisco jabber for iphone and for android is not working with an error "cannot loacte server"".
CUCM v 9.1.2
Please advise the possible issue and troubleshooting steps.
09-09-2014 01:25 PM
DNS issues, SRV issues, connectivity issues would be the first things to check, then to make sure the configuration is as explained in the configuration guide.
09-10-2014 12:18 PM
DNS and connectivity is fine as jabber for desktop and iphone is working.
I need to add Cop file for the android in CUCM?
Is this the liceses issue?
or may be android phone issue?
09-11-2014 02:44 AM
When you created the Device in CUCM, is the Product Type set to "Cisco Dual Mode for Android" and Device Protocol "SIP"?
Also the Device Name starting with BOT and a Directory Number is assigned?
09-12-2014 10:15 PM
09-12-2014 10:49 PM
Hi Waqas,
You mush install cop file for the android in CUCM, it should be works after you install cop file.
