Community Member
Cisco Jabber for CME
Hi all,
i'm trying to configure Cisco CME v.9.5 to work with Cisco Jabber for Android.
I could not find any official cisco documents regarding this question, and performed a configuration using different internet sources.
Here is a config
voice register global
mode cme
source-address port 5060
max-dn 100
max-pool 15
authenticate presence
authenticate register
authenticate realm itmax
timezone 31
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 0392202201906802
ntp-server mode directedbroadcast
voice register dn  2
number 680
voice register pool  2
registration-timer max 720 min 660
id mac 5CE2.F454.273D
type Jabber-Android
number 1 dn 2
username 680 password default
codec g711ulaw
According to
show voice register pool 2
the mobile client has registered
it-max.cme#show voice register pool 2
Pool Tag 2
  Mac address is 5CE2.F454.273D
  Type is Jabber-Android
  Number list 1 : DN 2
  Proxy Ip address is
  Current Phone load version is Cisco-CiscoMobile 8.6/9.2.1
  DTMF Relay is disabled
  Call Waiting is enabled
  DnD is disabled
  Video is disabled
  Camera is disabled
  Busy trigger per button value is 0
  keep-conference is enabled
  registration expires timer max is 720 and min is 660
  kpml signal is enabled
  Lpcor Type is none
  Transport type is udp
  service-control mechanism is supported
  registration Call ID is 00000000-00000002-1eccd69a-379b84b4@
  Registration method: per line
  Privacy feature is not configured.
  Privacy button is disabled
  active primary line is: 680
  contact IP address: port 58143
  Phone SIS Version:  5.2.0
  GW SIS Version:  1.0.0
  conference admin: no
  conference add mode: all
  conference drop mode: never
  paging-dn: config 0 [multicast]  effective 0 [multicast]
Dialpeers created:
Dial-peers for Pool 2:
dial-peer voice 40002 voip
destination-pattern 680$
session target ipv4:
session protocol sipv2
digit collect kpml
codec  g711ulaw bytes 160
  after-hours-exempt   FALSE
  Active registrations  : 1
  Total SIP phones registered: 2
  Total Registration Statistics
    Registration requests  : 3
    Registration success   : 3
    Registration failed    : 0
    unRegister requests    : 2
    unRegister success     : 2
    unRegister failed      : 0
The inbound calls from the Android smatphone using Jabber works OK, but the phone does not receive any inbound calls.
Also, when i enable debug ccsip messages - i didn't see any information regaridng the call.
Did anyone was able to perform a successful configuration for outbound/inbound calls for Jabber for CME?
