Community Member
Cisco Jabber no incoming audio MRA
Hi Team,
I have a problem that there is no audio for incoming calls when Cisco Jabber on MRA through internet
Cisco Jabber Windows is working fine incoming and outgoing
outgoing calls for android and IPhone is working fine
only the problem in incoming calls to android and iphone
Everyone's tags (1)
Community Member
Its 100% related to routing
Its 100% related to routing and firewall issue.,let me know what firewall you are using?
Community Member
it's working with jabber
it's working with jabber windows
this problem for android and iphone, see below the different between windows call and android
Community Member
i noticed in call logs of
i noticed in call logs of expressway E
android and IPhone the call type is Video
but with windows which is working the call type is Audio
Community Member
Hi,i keep searching for a
i keep searching for a solution for this issue then i found this discussion
https://supportforums.cisco.com/discussion/12168781/cisco-jabber-iphone-961-and-jabber-android-not-working-vcs-expressway
i am hitting a bug , i will upgrade the cucm then i will update the discussion
Community Member
I could resolve the issue by
I could resolve the issue by the upgrades Thanks sivakalam for your attempt
1198
