Cisco jabber pause and speed dial
Hi all,
Is it possible to do pause in jabber, like, dialing the phone number, pause, extension number?
Also, how to use speed dials in jabber?
By the way, I have created a speed dial number for the physical phone with a comma and it worked great.
Tried to do the same with jabber, and it did not.
I am using version 9.2.2 build 3271
2 ACCEPTED SOLUTIONS
The speed dial concept does not exist for J4W, and thus, speed dial with pause also does not apply.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: Cisco jabber pause and speed dial
No, there's no character to insert a pause.
Roadmap questions cannot be addressed at CSC, engage your AM for that.
java
java
java
java
Thank you for the prompt response.
And there is no special caracter that can do pause even if I type it in jabber?
Is this feature in the roadmap for next versions?
java
java
996
