Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco jabber publish over internet
Dear Team,
We have installed Cisco jabber (J4W, J4A, J4I) and want to connect from outside. We want to publish over internet. Plz advise which software and server we required for the same?
1 ACCEPTED SOLUTION
Review all requirements in
Review all requirements in the official Cisco documentation
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-1/Mobile-Remote-Access-via-VCS-Deployment-Guide-X8-1-1.pdf
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Super Bronze
You need expressway-e and
You need expressway-e and expressway-c servers..Please refer to this blog for a step by step guide
http://pandaeatsbamboo.blogspot.co.uk/2014/06/collaboration-edge-expressway-step-by.html
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
  Thanks We need to open some
We need to open some ports from service provider for the Expressway-C and E implementation?
Any additional requirement from client ?
java
204
