Cisco Jabber Softphone not working
The softphone is not working for cisco jabber windows
Attached is the logs
CUCM AND CUPS version 9.x
I found the below but is not clear to me what is the issue
2013-10-10 12:53:42,577 DEBUG [0x00001360] [tionplugin\StatusBarPhoneButton.cpp(127)] [plugin-runtime] [OnCanSelectDeskphone] - enabling deskphone menu items
2013-10-10 12:53:42,577 DEBUG [0x000011a8] [src\config\TftpHelper.cpp(114)] [csf.ecc] [ecc::TftpHelper::doRetrieveFile] - Received error: eFileNotFound downloading file using HTTP from 'http://10.255.0.11:6970/CTLSEPCSFKIKACHRISTOU.tlv', not trying TFTP following an explicit HTTP "not found" error.
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
  • IP Telephony
Do you have any idea about thi issue?
Have you created a jabber-config.xml file and uploaded to your tftp servers?
Cheers
Ben
Please rate if this post is useful
Hi Morgan. Is it really necessary to create jabber-config.xml on IM-P 9.x ? Asked 'cause i've implemented it without including this file.
If some jabber users are not into the domain then its neccesary the xml file ...
If is not appear into the jabber the config for the phone services then its good upload the xml file
And general if you want some extra features then the xml file is your way
Otherwise is not neccesary
Chrysostomos
VIP Super Bronze
Can you describe what is not working? Can you loggin to Jabber? Does it register? What is the actual problem
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Everything working ok except the softphone.We can login to the jabber , we can control the deskphone , chat, etc BUT the softphone(CSF) profile does not register into cucm
The xml file has been uploaded to cucms
Chrysostomos
VIP Super Bronze
What is the username of the user in this log?
username: KIKACHRISTOU
Chrysostomos
VIP Super Bronze
Chrys,
Do you have owner user id set on the CSF?
Do you have the primary DN set for the user on the user management page?
899
