Community Member
Cisco Jabber Voice (iPhone & Android) on CME
Hi All UC Experts,
I just tried the Jabber Voice (iPhone & Android) on CME. Basically, I still cannot register the Jabber Voice (Android) to the configurated CME.
I saw the concept is so simple as the sip server as 5060 and the Jabber Voice on CME should be no need the phone load, so it just used the sip for registration to the CME.
I'm working on the guide as: http://www.firewall.cx/cisco-technical-knowledgebase/cisco-voice/907-cisco-voice-jabber-android-iphone.html
voice register global
 mode cme
 source-address 192.168.9.5 port 5060
 max-dn 8
 max-pool 8
 authenticate register
 authenticate realm firewallcx
 tftp-path flash:
 file text
 create profile sync 0033775744721428
(What's the mean on "create profile sync 0033775744721428" ?)
voice register dn  5
 number 778
 name Chris-Android 778
 label Chris-Android 778
voice register pool  1
 registration-timer max 720 min 660
 id mac 147D.C5AF.79B2
 session-transport tcp
 type Jabber-Android
 number 1 dn 5
 username chris password firewallcx  <--- (Only for iPhone?)
 codec g729r8
Why I still not work to register the Jabber Voice on CME? Any ideas?
How can  I make the easy method to add a new Jabber user?
Can you show us what the SIP
Can you show us what the SIP messaging looks like when the phone tries to register?
debug ccsip messages
Community Member
Router#sh runBuilding
Router#sh run
Building configuration...
Current configuration : 3698 bytes
! Last configuration change at 12:52:12 UTC Wed Apr 30 2014
version 15.3
hostname Router
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.153-2.T.bin
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
no aaa new-model
ip cef
no ipv6 cef
voice-card 0
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 3600 min 3600
 mode cme
 source-address 192.168.1.50 port 5060
 max-dn 56
 max-pool 14
 authenticate realm <password>
 tftp-path flash:
 create profile sync 0028434695579459
voice register dn  1
 number 1122
voice register dn  2
 number 2211
voice register dn  3
 number 1212
voice register template  1
 id mac D420.XXXX.XXXX
 type Jabber-Android
 number 1 dn 1
 dtmf-relay sip-notify
 codec g711ulaw
voice register pool  2
 id mac 28E1.XXXX.XXXX
 type CiscoMobile-iOS
 number 1 dn 2
 username user01 password <password>
 codec g711ulaw
voice register pool  3
 id mac 0026.XXXX.XXXX
 number 1 dn 3
 username user02 password <password>
 codec g711ulaw
application
 global
  service alternate default
license udi pid CISCO2921/K9 sn FXXXXXXXXXX
license accept end user agreement
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
hw-module sm 1
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 ip address 192.168.1.50 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface SM1/0
 no ip address
 shutdown
 !Application: Cisco UMG running on SM
 hold-queue 60 out
interface SM1/1
 description Internal switch interface connected to Service Module
 no ip address
 shutdown
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sip-ua
 presence enable
gatekeeper
 shutdown
telephony-service
 max-ephones 10
 max-dn 10
 ip source-address 192.168.1.50 port 2000
 max-conferences 8 gain -6
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
 stopbits 1
 flowcontrol software
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Router#ter monitor
% Console already monitors
Router#debu
Router#debug voice register event
voice-register events debugging is on
Router#debug tftp events
TFTP Event debugging is on
Router#
*Apr 30 12:15:59.975: TFTP: Looking for SEPD420XXXXXXXX.cnf.xml
*Apr 30 12:15:59.975: TFTP: Opened flash:/its/SEPD420XXXXXXXX.cnf.xml, fd 14, size 3799 for process 114
*Apr 30 12:16:00.231: TFTP: Finished flash:/its/SEPD420XXXXXXXX.cnf.xml, time 00:00:00 for process 114
*Apr 30 12:16:39.055: TFTP: Looking for SEPD420XXXXXXXX.cnf.xml
*Apr 30 12:16:39.059: TFTP: Opened flash:/its/SEPD420XXXXXXXX.cnf.xml, fd 14, size 3799 for process 114
*Apr 30 12:16:39.311: TFTP: Finished flash:/its/SEPD420XXXXXXXX.cnf.xml, time 00:00:00 for process 114
Router#debug ccsip messages
SIP Call messages tracing is enabled
Router#
*Apr 30 13:05:06.079: TFTP: Looking for SEPD420XXXXXXXX.cnf.xml
*Apr 30 13:05:06.083: TFTP: Opened flash:/its/SEPD420XXXXXXXX.cnf.xml, fd 14, size 3799 for process 114
*Apr 30 13:05:06.387: TFTP: Finished flash:/its/SEPD420XXXXXXXX.cnf.xml, time 00:00:00 for process 114
Try doing a problem report in
Try doing a problem report in the app and download those logs.
Community Member
This is the Jabber App log
This is the Jabber App log for the iPhone with "voice register pool  2".
The phone seems to be getting
The phone seems to be getting the config file but it's failing to parse the file.
Try doing a "no create profile" then "create profile" under "voice register global".
Also, try downloading "SEP28E14CA07AC8.cnf.xml" from 192.168.1.50 with a TFTP client on your PC.
Community Member
When the iPhone Jabber voice
When the iPhone Jabber voice try to register the CME that showed the debug as ...
"Looking for  .... AppDialRules.xml"
"Looking for  .... DirLookupDialRules.xml"
What's functions on the two files? Should I upload the two xml file to CME? Any content for the two xml files?
Community Member
It is working, after I
It is working, after I modified the <password> are matched.
That mean ...
authenticate realm 112233
username user01 password 112233
Why the users' password must match the global password?
& I discovered the Android only worked on the Samsung ... Not work on HTC, Sony ...
Community Member
Hi All,Is it official support
Hi All,
Is it official support for the Jabber on iPhone / Android of CME?
I am running  Version 15.1(4
I am running  Version 15.1(4)M6  ( "flash:uc500-advipservicesk9-mz.151-4.M6") all I had to change to get mine working.
My iphone works perfect and I have used the same link as you have.
voice service voip
 sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  registrar server
 mode cme
 source-address 172.25.185.100 port 5060
 max-dn 56
 max-pool 14
 authenticate realm xxxx
 tftp-path flash:
 file text
 create profile sync 0221166027520175
voice register dn  1
 number 1122
 name xxxx
 label xxxx
 id mac xxxx.xxxx.xxxx
 number 1 dn 1
 username xxxx password xxxx
 codec g711ulaw
Voice CCIE #37771
Community Member
Thanks for your help~ Did u
Did u try the Android platform?
Must be entered the username and password on iPhone? Will not be needed on Android?
2055
