Cisco Key Expansion Module supports CUCME?
Hi all!
We have Cisco IP phones model: 8961 with Key Expansion Module.
Phones powered by POE may therefore Key Expansion Module not working (If i buy 48V DC, 5W per KEM power adapter maybe its working).
We have CUCME but in documentation :
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-color-key-expansion-module/data_sheet_c78-565427.html
Call-control compatibility :
Cisco Unified Communications Manager 7.1(3) and later; Cisco Unified Survivable Remote Site Telephony (SRST) 7.1 (Cisco IOS® Software Release 12.4(24)T) and later
Its mean CUCME is not supported for Key Expansion Module???
Anybody know about CUCME and Key Expansion Module for 8961?
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
upgrade to ios System image
upgrade to ios
System image file is "flash:c2900-universalk9-mz.SPA.151-4.M8.bin"
and you will get CME 8.6
2921#sh telephony-service
CONFIG (Version=8.6)
Version 8.6
Hi, I remember that 8961 with
I remember that 8961 with Key Expansion Module is only supported in version 9.X and later in cme.
Please rate
Stefan
what is your router? can you
what is your router? can you upgrade ios to latest?
https://supportforums.cisco.com/discussion/11586586/latest-supported-ios-cisco-2811
latest ios for 2811
Before the IOS 15.x?
12.4T(24)
Alessio
Cisco IOS Software, C2900
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9_NPE-M), Version 15.3(3)M, RELEASE SOFTWARE (fc2)
upgrade to ios
Version 8.6
Does your network switch
Does your network switch support 802.3AT power over Ethernet?   If not you will require external power for the key expansion module.  Please see the link below.  I gleamed this from the link
Power Requirements
If the Cisco Unified IP Color Key Expansion Module is connected to a Cisco Unified IP Phone that uses 802.3AT power, a local power supply is not required. If the phone uses 802.3AF power, you must connect a power cube to it for it to supply power for all connected key expansion modules. If the phone is already locally powered by a power cube, no additional power cube is required when installing the key expansion module to it.
Please rate
Stefan
Thanks for your answers guys
Thanks for your answers guys!
show telephony-service
CONFIG (Version=10.0)
Version 10.0
I  buy power adapter and if Key Module not working with module second step try upgrade ios
95
