Cisco MediaSence on CUCM specification
Friends,
Please, I am planning to have cisco media server in place to record and to monitor calls between few ip phones and the inbound calls from PSTN. I have CUCM 7(1)2 running on a cluster of 2 subscribers and a publisher on  MCS 7825 I3 platform. What hardware and software specifications do you recommend  for the recording server and 3rd party apps to get this done excellently? Thanks in anticipation
1 REPLY
I don't see a mediasense
I don't see a mediasense version that supports 7.1(2) in the compatibility matrix- http://docwiki.cisco.com/wiki/Cisco_MediaSense_Compatibility_Matrix
You're probably going to need to upgrade your CUCM cluster if you want to use MediaSense.
Here's the hardware requirement for virtualizing MediaSense- http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_MediaSense
You may be able to run it on bare metal as long as your specs meet those requirements.  It would be much safer to virtualize it though.
26
