Community Member
Cisco Messaging Interface - Service Status DOWN
We upgraded from CM 4.2 to 7.0(1). Everything looks like it's working okay except we're getting Cristical Service Down messages in RTMT - Service Status is down, Cisco Messaging Interface. Alerts are popping up almost every minute. Any ideas where to start looking?
1 ACCEPTED SOLUTION
Re: Cisco Messaging Interface - Service Status DOWN
legacy meaning an SMDI integration. Unity is SCCP or SIP, doesn't need at all the CMI service
java
if this helps, please rate
java
www.cisco.com/go/pdi
are you using a legacy VM integration???
if not, then there's nothing to worry about as that service if for that purpose
java
java
Community Member
As long as Unity isn't considered a legacy VM app. Can I disable this service?
Thank you.
java
java
Community Member
Thank you.
3531
