Cisco Messaging Interface
I was looking around in the RTMT for our system and found that there is an alert regarding the 'Cisco Messaging Service' being down. I verified that it is activated but not running in the serviceability page. I was going to restart the service but since I cannot find any documentation as to what it actually does I did not want to take a chance on restarting it. If anybody knows what that service is or does and could point me to some documentation I would appreciate it.
Thanks - Matt
1 ACCEPTED SOLUTION
Re: Cisco Messaging Interface
no, SMDI is a legacy VM integration and that's the main purpose of the CMI
there is no need to start the service for a CUC integration, or unity, or CUE for that matter
java
if this helps, please rate
java
www.cisco.com/go/pdi
it's used for legacy VM integrations, SMDI.
if you're not using any, there is no need to start the service
java
java
Thanks for the reply. We are using Cisco Unity Connection for our voice mail. Do you know if that would be considered a legacy VM?
Matt
java
java
Thank you again. That clears it up for me, just one more thing. Should I set that so that the service is no activated or does it not really make any difference? It has been functioning this way for a couple of months now so I don't see the harm but if it will clear up the alerts in the RTMT and not afect anything I would prefer to just change it.
Thanks - Matt
the recommendation is to leave it stopped unless going to use it.
same as CAPF, if not using it, leave it stopped.
simply ignore the alerts
java
java
Thank you very much.
262
