Community Member
cisco mobile 8.0
Has anyone gotton this to work on ccm 7.13 without rebooting the cluster? Is it really necessary?
Re: cisco mobile 8.0
I assume you mean this since you don't mention reboot after what?
Making the Cisco Mobile 8.0 Device Available on Cisco Unified  Communications Manager
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cumc/cisco_mobile/iPhone/8_0/Cisco_Mobile_iPhone_8x_Admin_Guide.html#wp288341
If so, the answer is yes. Support for new devices requires a MANDATORY cluster reboot.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
yes, after installing the .cop file, the admin guide says rebo
ot.  You usually don't have to reboot after adding a new phone firmware..
thanks
Correct, but you're not adding a phone FW, you're adding a new device model.
Just look at the name of the procedure:
java
java
The link is fine, try removing /partner from the url.
java
java
583
