Cisco Mobile 8 (iphone) only rings once on incoming call
We have just installed Cisco Mobile 8 on two iphones. Dialing out work fine however only 1 in around 10 incoming call cause the phone to ring normally, for all other incoming calls the iphone rings once and then stops. The call continues to ring on the shared line on the desk phone.
I've seen a couple of other postings regarding this issue but no one appears to have an answer to it.
We are using shared lines with CFNA set to 20secs, therefore this shouldn't be the issue.
Can anyone offer any advice on this issue.
Cisco Mobile Version:8.0.2
CUCM version: 7.1.3.32900-4
Thanks in advance,
Chris
  • IP Telephony
Everyone's tags (4)
1 REPLY
Re: Cisco Mobile 8 (iphone) only rings once on incoming call
Chris,
Since I have also been having this problem I wanted to check with you, are the phones you are using 3g, 3gs, or 4? I have not had the oppertunity to test on 4. My 3gs phone I have setup works fine, and the 2 3g phones are doing the single ring and nothing else.
995
