Cisco Mobile Connect
If I have initiated a call on my Cisco desk phone and I want to continue the call on my cell-phone, can I use the Cisco Mobile Connect Service?
If yes, could you please tell more details on using the service?
Thank you.
Re: Cisco Mobile Connect
With Cisco Mobility in CM 6+ you can have a User associated with a Desk Phone and a Remote Destination (Cell Phone). If you initiate a call on the desk phone, once established, you can use the mobility key to pass the call to the cell phone. The call path remains through the Cm so you can take the call back by hanging up on the cell phone.
Liam
Thanks for the information, it was helpful.
Hi Aarti,
           I hope you are doing well, well that's correct that if you receive a call on your desk phone that call will also be received on your cell-phone. You can also toggle between the two phones according to your availibility.
Please refer to the doccument below that i have created, i hope that it helps
https://supportforums.cisco.com/docs/DOC-8454
Please let me know if there are any help/clarifications that you need on this & id be glad to help you.
Amit
Thank you so much for your reply. Your document was also very useful.
When the remote phone is answered the call, the original IP Phone should  see a message "IN Use Remote" mode. Is it need to enable some parameter in CUCM, please light me.
2225
