Cisco Mobile Fails through VPN
Dear Community
I have Cisco Mobile on iPhone which works great on local wifi. When I try to connect through VPN, it goes to connecting-no registered loop. CCM address is reachible through VPN.What could be your suggestion?
What is the VPN client & VPN concentrator used in your setup ?
Cisco has tested it with Cisco Anyconnect VPN Client with Cisco ASA as VPN Concentrator. Others might/might not work.
Pls rate the post if it helps ?
GP.
Also check if your internet data connection ( used for VPN ) meets minimum required specifications given in CUCM SRND guide.
GP
Thank you for your answer friend,We are using ASA and native VPN client on iPhone. I don't think it's a bw issue, was tested on 3g and home wifi with 4-5 mbps speed.
212
