hj
Cisco Mobility Transfer call on a Mobile
Hi does anyone know a Application for mobile phones where you can preset you
Enterprise Feature Access DID, and all of the rest settings so the only thing you
have to do is insert the number you whis to transfer the call to ?
I think it is hard for the user tho rember how to transfer when it looks like this:
1. Enter: *82 (Exclusive Hold)
2. Make new call to Enterprise Feature Access DID.
3. On connect, enter:
<PIN_number> # *84 # <Transfer_Target/DN> #
4. Upon answer by transfer target (for consultive transfer) or upon ringback (for early attended transfer), enter: *84
Or just another way to transfer  through the cucm when using mobility ?
Henrik Jensen
DK
Hi Henrik.
You can configure Single Number Reach feature for users who need to use their mobile phone in conjuction with desk phone.
They can also enable/disable this feature via Mobile Voice Access application.
On following liks you can see how to enable these features.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmfeat/CUCM_BK_C3E0EFA0_00_cucm-features-services-guide-91_chapter_010001.html#CUCM_TK_C11CA04F_00
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmfeat/CUCM_BK_C3E0EFA0_00_cucm-features-services-guide-91_chapter_010001.html#CUCM_RF_ME133256_00
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
hj
Hi Carlo, thanks for the answer.
But I know that all ready
Im looking for a more easy way to transfer call from you mobile thug the CUCM when it is a mobility call.
So what im looking for is an Mobile application there can make transfer thrugh the mobililty feature more easy than it is to day.
Im thinking more like "hookswitch" like with analog phones.
Or a Application for the mobilephone where you fill out:
Mobility Enterprise Feature Access Number
Pin
Transfer code *84
And then you just type in the number you want tranfer to.
Re: Cisco Mobility Transfer call on a Mobile
Cisco jabber voice.
hj
That could be a possibility, but what if they are not having Wifi or their mobile phones not are smartphone(Android or IOS) ?
Thanks for the idea
Hi Henrik.
In that case you can use third party sip client
Carlo
hj
If i have some mobiles there is Carrier-Integrated Mobile.
Is there another way to transfer mobil calls then ?
266
