Cisco NME-CUE Voice mail licensing.
Hi, I need to know which serial number do I use in order to generate license files for unity express 8.0? do I use Router serial or NME-CUE module serial?
Everyone's tags (4)
1 ACCEPTED SOLUTION
Blue
HI
show license udi on router will provide you product ID (PID) and the serial number (SN). This will be required to generate license file.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
HI
Ronak Patel
Rate helpful posts.
Blue
Show license udi should be run on CUE module where the licenses are to be installed not on router itself. I just saw that I have written router instead of CUE module in my reply.
Ronak Patel
651
