Cisco - PBX problem - LOS detected
Hi guys,
I have two routers, a 3745 with c3745-ipvoicek9-mz.124-18.bin and a 2811 with c2800nm-spservicesk9-mz.124-3i.bin connected to a PBX Mitel.
Both my routers connect to the Pbx via on E1.
The configs are
3745:
sh run | s controll
controller E1 1/0
pri-group timeslots 1-31 service mgcp
controller E1 1/1
shutdown
sh run | s Serial
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 120000
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
2811
sh run | s controll
controller E1 0/0/0
sh run | s Serial
interface Serial0/0/0:15
no ip address
isdn T310 120000
no cdp enable
The problem is that from time to time (about 20 times a month) the E1 connection is dropped and then restarted in a couple of minutes.
This is a log form the routers
006980: Aug 26 11:37:52.711: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (LOS detected)
006981: Aug 26 11:37:52.739: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to down
006982: Aug 26 11:37:54.712: %LINK-3-UPDOWN: Interface Serial0/0/0:15, changed state to down
006983: Aug 26 11:38:38.712: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
006984: Aug 26 11:38:40.712: %LINK-3-UPDOWN: Interface Serial0/0/0:15, changed state to up
006985: Aug 26 11:39:29.305: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to up
I can see the reason is LOS detected but i don't really know what that is.
Can anyone help me please?
Thank you,
Good day.
Hall of Fame Super Gold
Re: Cisco - PBX problem - LOS detected
you should use "clock source internal" for this connection.
Also check you're using proper 120 Ohm cable with the right pairing.
Indeed my conf on CUCM 7 is clock source external. My question is why do you think changing the clock source will solve the problem?
Thank you very much for your help.
Clock source must be internal, because from your configuraation appears that PBX is left as "user side".
6911
