Cisco Phone Designer on CUCM 8.5.1 not working
Dear Community,
Upon upgrading our CUCM 6.1.3 to version 8.5.1 we have noticed that the Cisco Phone Designer is not anymore operational. While trying to change the Wallpaper on a phone that has already i receive teh error: The URL is incvalid.
Moreover, when I try to upload a new ringtone (even one of the predefined on the CPD) on the phone, while trying to preview the ringtone on the phone there is no audio.
Can anyone assist on the above? Cisco Phone Designer is a nice tool especially for "advertising" the capabilities of the Cisco Phone Devices.
Many thanks in advance for any comments.
George
Hall of Fame Super Silver
Correct, Cisco announced End of Life of this widget some time ago, see here:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps9829/end_of_life_notice_c51-663729.html
and there is not replacement product unfortunatelly from Cisco.
HTH,
Chris
Hello Chris,
Thanks for your reply, but the application was working until the time that we upgraded to 8.5.1 and I havent seen incompatibility with the CUCM version? Could that be something else?
George
Bronze
I'm running teh phone designer with my 8.5 CUCM with no issues (apart from an issue with Win7 64bit). Check out the log files: (As per the installation Guide)
C:\Program Files\Cisco Systems\Cisco Unified Phone Application\LogFiles
. The most recent log file is called phonePersonalization.log
Post it here if you can't see anything.
Gareth
Hello Gareth,
Please check below part of the log file (since i didnt manage to attach it):
2012-08-29 19:54:37,438 [1] DEBUG - Closing stream
2012-08-29 19:54:37,438 [1] INFO  - SetRingtone personalisationResponse.Data
InvalidURL
  Http Failed
2012-08-29 19:54:37,439 [1] INFO  - returning from SetRingtonePreview, success = True
2012-08-29 19:54:37,441 [1] INFO  - Starting InitializePlayOnPhoneTimer for TimerPlayTick
2012-08-29 19:54:37,447 [1] INFO  - Playing Ringtone List file - Cisco Synthesizer.raw
2012-08-29 19:54:37,448 [1] INFO  - Previewed Cisco Synthesizer.raw on SEPE8BA70FB2205
2012-08-29 19:54:58,687 [1] INFO  - OnExecutedPlayPhoneFrame Starting
2012-08-29 19:54:58,688 [1] INFO  - PlaySavedRingToneOnPhone Starting
2012-08-29 19:54:58,688 [1] INFO  - Cache file = SEPE8BA70FB2205_Analog Synthesizer 2.raw
2012-08-29 19:54:58,689 [1] INFO  - Entering SetRingtonePreview - 10.2.1.250 - gsotiropoulos - SEPE8BA70FB2205 - C:\Users\gsotiropoulos\AppData\Roaming\Cisco\Cisco Unified Phone Application\Data\Cache\SEPE8BA70FB2205_Analog Synthesizer 2.raw
2012-08-29 19:54:58,689 [1] DEBUG - Ringtone request XML  :SEPE8BA70FB2205DesignerRingtone
2012-08-29 19:55:01,120 [1] DEBUG - response =
2012-08-29 19:55:01,120 [1] DEBUG - response.StatusCode = OK
2012-08-29 19:55:01,120 [1] DEBUG - starting response.GetResponseStream()
2012-08-29 19:55:01,120 [1] DEBUG - result stream =
InvalidURL
  Http Failed
2012-08-29 19:55:01,120 [1] DEBUG - Closing stream
2012-08-29 19:55:01,120 [1] INFO  - SetRingtone personalisationResponse.Data
InvalidURL
  Http Failed
2012-08-29 19:55:01,120 [1] INFO  - returning from SetRingtonePreview, success = True
2012-08-29 19:55:01,120 [1] INFO  - PlaySavedRingToneOnPhone success
2012-08-29 19:55:01,121 [1] INFO  - Starting InitializePlayOnPhoneTimer for TimerPlayTick
2012-08-29 19:55:01,126 [1] INFO  - Playing cached file - SEPE8BA70FB2205_Analog Synthesizer 2.raw
2012-08-29 19:55:01,126 [1] INFO  - OnExecutedPlayPhoneFrame Success
2012-08-29 19:56:43,871 [1] INFO  - OnExecutedPlayPhoneFrame Starting
2012-08-29 19:56:43,871 [1] INFO  - PlaySavedRingToneOnPhone Starting
2012-08-29 19:56:43,871 [1] INFO  - Cache file = SEPE8BA70FB2205_Analog Synthesizer 2.raw
2012-08-29 19:56:43,871 [1] INFO  - Entering SetRingtonePreview - 10.2.1.250 - gsotiropoulos - SEPE8BA70FB2205 - C:\Users\gsotiropoulos\AppData\Roaming\Cisco\Cisco Unified Phone Application\Data\Cache\SEPE8BA70FB2205_Analog Synthesizer 2.raw
2012-08-29 19:56:43,872 [1] DEBUG - Ringtone request XML  :SEPE8BA70FB2205DesignerRingtone
2012-08-29 19:56:46,305 [1] DEBUG - response =
2012-08-29 19:56:46,305 [1] DEBUG - response.StatusCode = OK
2012-08-29 19:56:46,306 [1] DEBUG - starting response.GetResponseStream()
2012-08-29 19:56:46,306 [1] DEBUG - result stream =
InvalidURL
  Http Failed
2012-08-29 19:56:46,306 [1] DEBUG - Closing stream
2012-08-29 19:56:46,306 [1] INFO  - SetRingtone personalisationResponse.Data
InvalidURL
  Http Failed
2012-08-29 19:56:46,306 [1] INFO  - returning from SetRingtonePreview, success = True
2012-08-29 19:56:46,306 [1] INFO  - PlaySavedRingToneOnPhone success
2012-08-29 19:56:46,306 [1] INFO  - Starting InitializePlayOnPhoneTimer for TimerPlayTick
2012-08-29 19:56:46,311 [1] INFO  - Playing cached file - SEPE8BA70FB2205_Analog Synthesizer 2.raw
2012-08-29 19:56:46,312 [1] INFO  - OnExecutedPlayPhoneFrame Success
2012-08-29 19:57:05,279 [1] INFO  - OnExecutedPlayPhoneFrame Starting
2012-08-29 19:57:05,280 [1] INFO  - PlaySavedRingToneOnPhone Starting
2012-08-29 19:57:05,280 [1] INFO  - Cache file = SEPE8BA70FB2205_Analog Synthesizer 2.raw
2012-08-29 19:57:05,280 [1] INFO  - Entering SetRingtonePreview - 10.2.1.250 - gsotiropoulos - SEPE8BA70FB2205 - C:\Users\gsotiropoulos\AppData\Roaming\Cisco\Cisco Unified Phone Application\Data\Cache\SEPE8BA70FB2205_Analog Synthesizer 2.raw
2012-08-29 19:57:05,280 [1] DEBUG - Ringtone request XML  :SEPE8BA70FB2205DesignerRingtone
2012-08-29 19:57:07,990 [1] DEBUG - response =
2012-08-29 19:57:07,990 [1] DEBUG - response.StatusCode = OK
2012-08-29 19:57:07,990 [1] DEBUG - starting response.GetResponseStream()
2012-08-29 19:57:07,991 [1] DEBUG - result stream =
InvalidURL
  Http Failed
2012-08-29 19:57:07,991 [1] DEBUG - Closing stream
2012-08-29 19:57:07,991 [1] INFO  - SetRingtone personalisationResponse.Data
InvalidURL
  Http Failed
Any help is much appreciated.
george
1789
