Cisco Phone Lock
Hi All
Hope you are ok.
I am looking a way to lock the phones for outbound call during some time period. I tested time of day routing but It lock the phones apparently for indbound call only. Please advise any suggest
Andres
1 ACCEPTED SOLUTION
Bronze
Re: Cisco Phone Lock
Time of day routing should work. I'd guess you probably also assigned the TOD to the partition of the directory number of the actual phones. The only partition you want to assign the TOD schedule to is the route pattern partitions which should be different than the directory number partitions. So for example, the phone has a directory number in the "Internal" partition. The route pattern for long distance is in the "LD" partition. Apply the TOD to the "LD" partition. This will make the "LD" partition only active during the time specified in the TOD schedule, thus restricting anyone from calling it per the TOD schedule while still being able to call the directory number on the phone which has no TOD schedule assigned to it.
VIP Super Bronze
Outbound calling can be controlled through Forced Authorization Codes (FACs). You could combine this with time of day routing so the FAC-enabled Route Patterns only were used during certain time periods.
Bronze
270
