Cisco Phone registration issue rejected, Error Mismatch
Facing issue with Cisco Phone registration Message Registration rejected, Error Mismatch
Tried re adding phone
Manual Firmware
Any suggestion
  • IP Telephony
Everyone's tags (3)
Hall of Fame Super Silver
Make sure the phone you configured is the exact type the phone is in reality. I.e. If phone is 7945 don't build it as 7965.
Chris
Phone type is correct 7942G
Did you check the switch port to see if it says 10/100/1000? If so, it is not 7942G. It would be 7942G-GE
Adding to Chris's suggestion, try to perfoming a Factory Reset to the phone, some Certificate issue could cause this problem too.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
Already done with factory reset
VIP Purple
Hi Dheeraj,
what is the CUCM version u are using?
Do u have enough licenses on CUCM to register new phone?
regds,
aman
Its Call Manager 4, i am able to add other phone
VIP Purple
Hi Dheeraj,
Hope u are correctly entering the MAC address in Call manager .
can u share the snapshot and mac-address of phone ?
regds,
aman
Was this phone registered to a CUCM 8 or above before being put on the CUCM 4?  If so, it could be the CTL.   You need to remove that through Admin mode on a 7942G, I believe.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7962g_7942g/6_0/english/administration/guide/7962net.html#wp1040906
6223
