ā09-30-2013 06:44 AM - edited ā03-16-2019 07:36 PM
which license does cisco phone with SIP firmware use? Enhanced UCL or something else?
Solved! Go to Solution.
ā09-30-2013 07:27 AM
7925/26, you can also use 9971 which are desk phone but can be used as wifi in areas where there is no cabling.
All of the above use 4 DLUs.
HTH, please rate all useful posts!
Chris
ā09-30-2013 06:52 AM
licensing is independent of protocol used, licensing is based on user needs and/or number and types of devices being used.
HTH,
Chris
ā09-30-2013 07:24 AM
and another question,
which are the best wifi sip phones supported by cucm 7.1.5, and what license do i need for them?
Chris
ā10-01-2013 01:16 AM
have you tested some third party SIP phones with CUCM? which of them could you recommend?
ā10-01-2013 01:37 AM
and what is the difference between 7925 and 7926, except in price ?
ā10-01-2013 05:23 AM
The main difference that comes to mind is the bar code scanner available on 7926, you can compare the data sheets for both to see if there is anything else.
HTH,
Chris
