CISCO phone with SIP firmware
which license does cisco phone with SIP firmware use? Enhanced UCL or something else?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
7925/26, you can also use 9971 which are desk phone but can be used as wifi in areas where there is no cabling.
All of the above  use 4 DLUs.
HTH, please rate all useful posts!
Chris
licensing is independent of protocol used, licensing is based on user needs and/or number and types of devices being used.
HTH,
Chris
and another question,
which are the best wifi sip phones supported by cucm 7.1.5, and what license do i need for them?
Chris
have you tested some third party SIP phones with CUCM? which of them could you recommend?
and what is the difference between 7925 and 7926, except in price ?
The main difference that comes to mind is the bar code scanner available on 7926, you can compare the data sheets for both to see if there is anything else.
HTH,
Chris
137
