Cisco Phones never switch to voice VLAN after switch reboot
I have just come across an issue during a new VoIP deployment.
We are using 3750G switches for access switches running IOS c3750-ipbasek9-mz.122-37.SE1.
The phones are a mix of Cisco 7965 and 7841s.
When I reload a switch all of the phones never switch over to the voice VLAN as I assume they should. The mac address table for a port with a phone and computer has 2 entries. 1 for the phone and 1 for the computer. Both in the data VLAN.
Here is a standard port config.
switchport access vlan 33
switchport mode access
switchport voice vlan 613
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
queue-set 2
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
To fix the issue I just bounce all of the ports on the switch and the phones come back up in the correct VLAN. I know that during the bootup process the phones negotiate the voice VLAN and I know the phones come up before the switch fully boots. However I would assume the phone should switch VLANs based on information it receives via CDP.
Elton
Community Member
Re:Cisco Phones never switch to voice VLAN after switch reboot
Can you post full show config? And show vlan ?
Sent from Cisco Technical Support Android App
Here ya go. I removed most of the access port configs as they were all the same and take up a lot of space.
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
hostname 310RM-3750-ST1
logging buffered 8092 informational
enable secret 5 XXXXXXXXXXXXXXXXXX
enable password 7 XXXXXXXXXXXXXX
username tacacsdown privilege 15 secret 5 XXXXXXXXXXXXX
aaa new-model
aaa group server radius RADIUSGROUP
server 10.69.16.100 auth-port 1812 acct-port 1813
server 10.69.17.20 auth-port 1812 acct-port 1813
aaa group server tacacs+ XXXXXXXXXX
server 10.38.96.28
server 10.38.96.29
server 10.39.96.29
aaa authentication login default group XXXXXXXX local
aaa authorization exec default group XXXXXXXXX local
aaa accounting exec default start-stop group XXXXXXXXX
aaa session-id common
clock timezone est -5
clock summer-time EDT recurring
switch 1 provision ws-c3750g-48ps
switch 2 provision ws-c3750g-48ps
system mtu routing 1500
ip subnet-zero
no ip domain-lookup
ip domain-name XXXXXXXXXXXX
ip tftp source-interface Vlan1
ip ssh version 2
login block-for 3 attempts 3 within 3
login on-failure log every 3
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2  1
mls qos srr-queue input cos-map queue 1 threshold 3  0
mls qos srr-queue input cos-map queue 2 threshold 1  2
mls qos srr-queue input cos-map queue 2 threshold 2  4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3  3 5
mls qos srr-queue input dscp-map queue 1 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3  0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3  32
mls qos srr-queue input dscp-map queue 2 threshold 1  16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2  33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2  49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2  57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3  5
mls qos srr-queue output cos-map queue 2 threshold 3  3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3  2 4
mls qos srr-queue output cos-map queue 4 threshold 2  1
mls qos srr-queue output cos-map queue 4 threshold 3  0
mls qos srr-queue output dscp-map queue 1 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3  48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3  56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3  16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3  32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1  8
mls qos srr-queue output dscp-map queue 4 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3  0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
crypto pki trustpoint TP-self-signed-2963009664
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2963009664
revocation-check none
rsakeypair TP-self-signed-2963009664
crypto pki certificate chain TP-self-signed-2963009664
certificate self-signed 01
  308202B4 3082021D A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  60312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32393633 30303936 3634312D 302B0609 2A864886 F70D0109
  02161E33 3130524D 2D333735 302D5354 312E646D 762E7374 6174652E 6E792E75
  73301E17 0D393330 33303130 30303332 355A170D 32303031 30313030 30303030
  5A306031 2F302D06 03550403 1326494F 532D5365 6C662D53 69676E65 642D4365
  72746966 69636174 652D3239 36333030 39363634 312D302B 06092A86 4886F70D
  01090216 1E333130 524D2D33 3735302D 5354312E 646D762E 73746174 652E6E79
  2E757330 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  BF4F08C6 05B48324 AC98D509 09F45EA2 3FB3EC15 D8D54E9E 0DA24B45 6AC7071A
  80B98F27 548A651C D6BC6745 139BDF36 88A00EAD F6168137 E22412DE DA36A6F9
  1F1E4616 8E6FEB98 B927F594 F9E93BE6 1DFC74F8 AF7C30EA FA6428FE B8211A82
  107EB5B7 0D8406E8 3C932B2B 10EE45DB CD4D219C AEF58265 252EF054 F6A4F747
  02030100 01A37E30 7C300F06 03551D13 0101FF04 05300301 01FF3029 0603551D
  11042230 20821E33 3130524D 2D333735 302D5354 312E646D 762E7374 6174652E
  6E792E75 73301F06 03551D23 04183016 8014C098 657145B6 655D93E6 7BDC2BE1
  46FA96DF F085301D 0603551D 0E041604 14C09865 7145B665 5D93E67B DC2BE146
  FA96DFF0 85300D06 092A8648 86F70D01 01040500 03818100 59FBD91A DA1A39B6
  A8122D40 AA6DC3E1 B66AFD5F 98B55A32 59AE5153 508ED513 AA602875 2EE89D2E
  47CB6BC4 3AAF79B7 34462AD9 AEBFA282 EA341698 B25AE228 D409922B 44687836
  BD5DAD2F 74692EA9 9F19CC0C 2D6A2427 FEEF87A8 299355E1 AEDF138D B6074B96
  9F55E176 D116FD9C 67EB5921 9F676381 44ADF357 D4CF05AF
  quit
errdisable recovery cause psecure-violation
errdisable recovery interval 30
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
description C1-41C
switchport trunk allowed vlan 1,16,33,98,599,613,901
switchport mode trunk
spanning-tree portfast disable
interface GigabitEthernet1/0/1
description UPS
queue-set 2
mls qos trust cos
interface GigabitEthernet1/0/2
queue-set 2
mls qos trust cos
interface GigabitEthernet1/0/49
description C1-41C
queue-set 2
mls qos trust cos
auto qos voip trust
channel-group 1 mode passive
interface GigabitEthernet1/0/50
description C1-41C
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/51
shutdown
no cdp enable
interface GigabitEthernet1/0/52
shutdown
no cdp enable
interface GigabitEthernet2/0/1
queue-set 2
mls qos trust cos
interface GigabitEthernet2/0/2
queue-set 2
mls qos trust cos
interface GigabitEthernet2/0/49
description C1-41C
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/50
description C1-41C
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/51
shutdown
no cdp enable
interface GigabitEthernet2/0/52
shutdown
no cdp enable
interface Vlan1
ip address 172.16.33.1 255.255.0.0
interface Vlan599
ip address 10.56.68.133 255.255.255.128
ip default-gateway 10.56.68.129
ip classless
no ip http server
ip http secure-server
ip tacacs source-interface Vlan599
ip access-list standard RO1
ip access-list extended VTY
permit tcp 10.69.66.0 0.0.0.255 any eq telnet log
permit tcp 10.69.66.0 0.0.0.255 any eq 22 log
permit tcp 172.16.0.0 0.0.255.255 any eq 22 log
permit tcp 172.16.0.0 0.0.255.255 any eq telnet log
permit tcp 10.69.31.0 0.0.0.255 any eq 22 log
permit tcp 10.69.31.0 0.0.0.255 any eq telnet log
permit tcp 1.11.1.0 0.0.0.255 any eq telnet log
permit tcp 1.11.1.0 0.0.0.255 any eq 22 log
permit tcp 10.48.32.96 0.0.0.7 any eq 22 log
permit tcp 10.48.32.88 0.0.0.7 any eq 22 log
permit tcp 10.48.24.16 0.0.0.15 any eq 22 log
permit tcp 10.38.97.0 0.0.0.255 any eq 22 log
permit tcp 10.38.96.0 0.0.0.255 any eq 22 log
permit tcp 10.39.97.0 0.0.0.255 any eq 22 log
permit tcp 10.77.16.0 0.0.1.255 any eq 22 log
permit tcp 10.48.56.32 0.0.0.7 any eq 22 log
permit tcp 10.36.0.0 0.3.255.255 any eq 22 log
permit tcp 10.48.40.0 0.0.0.127 any eq 22 log
permit tcp 10.53.65.128 0.0.0.15 any eq 22 log
permit tcp 10.53.65.144 0.0.0.15 any eq 22 log
permit tcp 10.63.128.0 0.0.0.255 any eq 22 log
permit tcp 10.63.129.0 0.0.0.255 any eq 22 log
permit tcp 10.56.68.128 0.0.0.127 any eq 22 log
deny   ip any any log
logging 10.69.27.129
logging 10.72.52.30
access-list 1 remark SNMP Managers
access-list 1 permit 10.69.31.97
access-list 1 permit 10.69.31.100
access-list 1 permit 10.69.31.101
access-list 1 permit 10.69.17.40
access-list 1 permit 10.69.30.242
access-list 1 permit 10.69.19.229
access-list 1 permit 10.69.27.129
access-list 4 permit 10.69.31.148
access-list 4 permit 10.69.31.149
access-list 4 permit 10.69.31.150
access-list 4 permit 10.69.31.151
access-list 101 deny   ospf any any
access-list 101 permit ip any any
snmp-server community XXXXXXXXXXXX RO 1
snmp-server community XXXXXXXXXX RW 1
snmp-server community XXXXXXXXXXX RO 4
snmp-server community XXXXXXXXX RO
snmp-server enable traps snmp coldstart warmstart
snmp-server enable traps flash insertion removal
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps license
snmp-server enable traps config
snmp-server enable traps syslog
snmp-server host 10.69.17.40 XXXXXXXXXXXX
snmp-server host 10.69.19.229 XXXXXXXXXXXX
snmp-server host 10.69.27.110 XXXXXXXXXXXX
snmp-server host 10.69.27.129 XXXXXXXXXXXX
snmp-server host 10.69.30.242 XXXXXXXXXXXX
snmp-server host 10.69.31.100 XXXXXXXXXXXX
snmp-server host 10.69.31.101 XXXXXXXXXXXX
snmp-server host 10.69.31.97 XXXXXXXXXXXXX
snmp-server host 10.38.96.70 XXXXXXXXXXXX
tacacs-server host 10.69.31.18 timeout 10
tacacs-server host 10.69.31.17
tacacs-server host 10.38.96.28
tacacs-server host 10.38.96.29
tacacs-server host 10.39.96.29
tacacs-server directed-request
tacacs-server key 7 XXXXXXXXXXXXXXXXXXXX
control-plane
banner motd ^C************************************
Unauthorized Entry To This Device Is
        STRICTLY PROHIBITED
************************************^C
line con 0
exec-timeout 120 0
password 7
logging synchronous
line vty 0 4
access-class VTY in
exec-timeout 120 0
password 7
logging synchronous
length 0
transport input telnet ssh
line vty 5 15
password 7
ntp clock-period 36029392
ntp server 10.38.96.37 prefer
ntp server 10.69.16.1
_________________________________________
1    default                          active    Gi1/0/1, Gi1/0/51, Gi1/0/52
                                                Gi2/0/50, Gi2/0/51, Gi2/0/52
33   RM310                            active    Gi1/0/2, Gi1/0/3, Gi1/0/4
                                                Gi1/0/5, Gi1/0/6, Gi1/0/7
                                                Gi1/0/8, Gi1/0/9, Gi1/0/10
VLAN Name                             Status    Ports
                                                Gi1/0/11, Gi1/0/12, Gi1/0/13
                                                Gi1/0/14, Gi1/0/15, Gi1/0/16
                                                Gi1/0/17, Gi1/0/18, Gi1/0/19
                                                Gi1/0/20, Gi1/0/21, Gi1/0/22
                                                Gi1/0/23, Gi1/0/24, Gi1/0/25
                                                Gi1/0/26, Gi1/0/27, Gi1/0/28
                                                Gi1/0/29, Gi1/0/30, Gi1/0/31
                                                Gi1/0/32, Gi1/0/33, Gi1/0/34
                                                Gi1/0/35, Gi1/0/36, Gi1/0/37
                                                Gi1/0/38, Gi1/0/39, Gi1/0/40
                                                Gi1/0/41, Gi1/0/42, Gi1/0/43
                                                Gi1/0/44, Gi1/0/45, Gi1/0/46
                                                Gi1/0/47, Gi1/0/48, Gi2/0/1
                                                Gi2/0/2, Gi2/0/3, Gi2/0/4
                                                Gi2/0/5, Gi2/0/6, Gi2/0/7
                                                Gi2/0/8, Gi2/0/9, Gi2/0/10
                                                Gi2/0/11, Gi2/0/12, Gi2/0/13
                                                Gi2/0/14, Gi2/0/15, Gi2/0/16
                                                Gi2/0/17, Gi2/0/18, Gi2/0/19
                                                Gi2/0/20, Gi2/0/21, Gi2/0/22
                                                Gi2/0/23, Gi2/0/24, Gi2/0/25
                                                Gi2/0/26, Gi2/0/27, Gi2/0/28
                                                Gi2/0/29, Gi2/0/30, Gi2/0/31
                                                Gi2/0/32, Gi2/0/33, Gi2/0/34
                                                Gi2/0/35, Gi2/0/36, Gi2/0/37
                                                Gi2/0/38, Gi2/0/39, Gi2/0/40
                                                Gi2/0/41, Gi2/0/42, Gi2/0/43
                                                Gi2/0/44, Gi2/0/45, Gi2/0/46
                                                Gi2/0/47, Gi2/0/48
613  VOICE-8P1-Core1-Floor3       active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/5, Gi1/0/6
                                                Gi1/0/7, Gi1/0/8, Gi1/0/9
                                                Gi1/0/10, Gi1/0/11, Gi1/0/12
                                                Gi1/0/13, Gi1/0/14, Gi1/0/15
                                                Gi1/0/16, Gi1/0/17, Gi1/0/18
                                                Gi1/0/19, Gi1/0/20, Gi1/0/21
                                                Gi1/0/22, Gi1/0/23, Gi1/0/24
                                                Gi1/0/25, Gi1/0/26, Gi1/0/27
                                                Gi1/0/28, Gi1/0/29, Gi1/0/30
                                                Gi1/0/31, Gi1/0/32, Gi1/0/33
                                                Gi1/0/34, Gi1/0/35, Gi1/0/36
                                                Gi1/0/37, Gi1/0/38, Gi1/0/39
                                                Gi1/0/40, Gi1/0/41, Gi1/0/42
                                                Gi1/0/43, Gi1/0/44, Gi1/0/45
                                                Gi1/0/46, Gi1/0/47, Gi1/0/48
                                                Gi2/0/1, Gi2/0/2, Gi2/0/3
                                                Gi2/0/4, Gi2/0/5, Gi2/0/6
                                                Gi2/0/7, Gi2/0/8, Gi2/0/9
                                                Gi2/0/10, Gi2/0/11, Gi2/0/12
                                                Gi2/0/13, Gi2/0/14, Gi2/0/15
                                                Gi2/0/16, Gi2/0/17, Gi2/0/18
                                                Gi2/0/19, Gi2/0/20, Gi2/0/21
                                                Gi2/0/22, Gi2/0/23, Gi2/0/24
                                                Gi2/0/25, Gi2/0/26, Gi2/0/27
                                                Gi2/0/28, Gi2/0/29, Gi2/0/30
                                                Gi2/0/31, Gi2/0/32, Gi2/0/33
                                                Gi2/0/34, Gi2/0/35, Gi2/0/36
                                                Gi2/0/37, Gi2/0/38, Gi2/0/39
                                                Gi2/0/40, Gi2/0/41, Gi2/0/42
                                                Gi2/0/43, Gi2/0/44, Gi2/0/45
                                                Gi2/0/46, Gi2/0/47, Gi2/0/48
Re: Cisco Phones never switch to voice VLAN after switch reboot
Just to clarify a little more it seems to only be the 7841 phones that don't move over to the voice VLAN after a switch reboot. The 7965 phones work just fine.
I also discovered this is only happening on our 3750 stacks of 2 or more switches. The single switch stacks don't have this issue.
Community Member
I didn't see any erorrs in the code.....you can try
interface vlan 613
no shut
exit
vlan 613
but since 613 is already up I dont think it would help.
At this point I would suggest attempting to upgrade firmware on the IOS and/or the phone and see if you are experiencing different results....might be a bug.
Hi Elton,
Can you please try below task and share with us:-
  • Reset the phone (7841) and see if phone gets the voice vlan normally.
  • Try to erase the phone configuration of any one phone (7841) and see if phone gets the voice vlan by normal process.
And as you said you are using Stack, then just confirm once that all the switches in stack are using the same "vlan.dat" file.
Nishant Savalia
Regards, Nishant Savalia
262
