Cisco phones takes more than 20 sec to connect the PSTN
Dears,
I have a Cisco 2921 CME with FXO four ports, all the ports contain land lines.
Now when I try to call outbound (PSTN) it took more than 20 Seconds, so please is there any configuration we can apply on the CME to reduce this time.
Apprecite your support,
Use interdigit timeout command under telephony-service. Something like:
telephony-service
timeouts interdigit
Please rate helpful answers!
Silver
You probably have overlapping dial-peers you need to correct.  Changing the interdigit timeout will just hide the problem and may cause problems for the users.
If you dial the number and wait until it connects, then release the call and hit the redial button the call should go inmediately. If this is correct it means that you have overlapping patterns and the dial plan should be changed to avoid this problem.
The problem is with POTS dial peer only below my dial peers that I applied on each voice port:-
dial-peer voice 1 pots
corlist outgoing PT-national
destination-pattern 07[4-9]........
incoming called-number .T
port 0/0/0
forward-digits all
dial-peer voice 2 pots
corlist outgoing PT-international
destination-pattern 00T
port 0/0/0
forward-digits all
dial-peer voice 3 pots
port 0/0/1
forward-digits all
dial-peer voice 4 pots
port 0/0/1
forward-digits all
dial-peer voice 5 pots
port 0/0/2
forward-digits all
dial-peer voice 6 pots
port 0/0/2
forward-digits all
dial-peer voice 7 pots
port 0/0/3
forward-digits all
dial-peer voice 8 pots
port 0/0/3
forward-digits all
dial-peer voice 9 pots
destination-pattern 06........
port 0/0/1
forward-digits all
dial-peer voice 10 pots
port 0/0/0
forward-digits all
dial-peer voice 11 pots
port 0/0/2
forward-digits all
dial-peer voice 12 pots
port 0/0/3
forward-digits all
port 0/0/0
forward-digits all
port 0/0/0
forward-digits all
port 0/0/1
forward-digits all
port 0/0/1
forward-digits all
port 0/0/2
forward-digits all
port 0/0/2
forward-digits all
port 0/0/3
forward-digits all
port 0/0/3
forward-digits all
port 0/0/1
forward-digits all
port 0/0/0
forward-digits all
port 0/0/2
forward-digits all
port 0/0/3
forward-digits all
Ali,
My understanding from your dial plan is that you have a variable length.
I recommend you to change the interdigit timeout to a lower value, perhaps 5 seconds or using the # sign after you finish dialing to avoid the timer.
telephony-service
timeouts interdigit
Hope this helps!
208
