Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco PLAR on CUCM 8
Would someone be kind enough to tell me how many PLAR's are support on CUCM 8.
I am currently running CUCM 8.0.3 and a C2851 ISR as my gateway.
Many thanks
Everyone's tags (4)
There's no hard limit, the only limit is HDD space since all that creates entries in the DB
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thank you for that info Java,
Is there a limit on the amout of dial-peers you can have on the gateway? obviously there will be some limit for pots as it will require timeslots on E1 and T1 cards or FXO/FXS cards.
Joe
Solution #K34857008
TitleHow to determine the maximum number  of dial-peers that can be configured on a router
Resolution
The dial-peer options are  available based on how much memory is available.
As an example, assume each dial-peer consumes 6k of  memory, and that the router does not accept new dial-peers at the 80  percent threshold of memory allocation. This formula calculates the  available dial-peer options:
(Free Memory * 0.8)/6k =  maximum theoretical number of configurable dial-peers
This number represents the upper limit.
These points must also be considered:
  • Check the real amount of free  RAM. Consider the real size of the decompressed Cisco IOS® and any  additional memory already used.
  • For each platform, it is necessary to calculate  the real quantity of memory consumed by each dial-peer.
Caution: More dial-peers can  adversely affect the performance of the router.
Issue the show  memory command in order to determine the amount of memory  that is used.
http://topic.cisco.com/taccc/voice_K34857008.html
java
java
735
