Cisco Prime Assurance install Help..!!!! :( :(
Hi all,
We would like to bring cisco prime assurance 9.1 in to our Organization
Guys could you please provide me install guide or screen shot of the  application for the assurance version 9.1 and I wanted to know the prerequisite  for this application like server requirement etc
We are having a UCS in which we can run a VM machine but I wanted to know is  cisco prime is installed on windows server 2008 ent edition R2,R1?
Or it has any OVI template like CUCM or how do I install and integrate  it?
Please help me to proceed in this case..
Rgds,
Rebecca
God bless u all!!
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Rebecca,
Here's the path to the ova's for download
Prime Collaboration Software-9.0
Cheers!
Rob
"When it comes to luck you make your own  "
- Springsteen
HI Rebecca,
I believe "Prime Assurance Manager" has beed EoL'd and replaced
with "Prime Infrastructure". You can see the notices and links to
the new product lines below
http://www.cisco.com/en/US/products/ps12349/index.html
Cheers!
Rob
- Springsteen
Hall of Fame Super Silver
Here are all the PRIME collaboration install guides:
http://www.cisco.com/en/US/partner/products/ps12363/prod_installation_guides_list.html
Chris
Hi all,
How do I download Cisco prime assurance 9.0 OVI template for VM please provide me link I was not able to find it.
Rebecca...!!!1
Hi Rebecca,
Cheers!
Rob
- Springsteen
Dear Rob,
I was able to install the application
But I am not able to login to GUI now I am entering the correct user name and password
As I had taken screen shot while configuring
I tried with admin and the password which i set NO GO
I tried with globaladmin as username and the same password NO GO
So I think I will have to reset the password now
Can I reset the password for the Web interface from CLI mode?? plz help iyts urgent
Rgds,
Rebecca
Hi Rebecca,
Well....at least you're getting there
I believe you'd need glabaladmin for the UI as admin is for cli;
User Accounts
For  Prime Collaboration, you will be required to specify various passwords  at different instances. This section is designed to help you specify  appropriate passwords in several scenarios that demand your login  credentials (applicable for both converged application and standalone  Prime Collaboration Assurance and Prime Collaboration Provisioning  applications).
globaladmin- A superuser who can access both Prime Collaboration Assurance and Prime Collaboration Provisioning UIs.
globaladmin  password- Specify this password when you configure your virtual  appliance for either standalone or converged applications. See Configuring the Prime Collaboration Assurance Virtual Appliance and Configuring the Prime Collaboration Provisioning Virtual Appliance. You are also required to specify this password when you log in to the UI (see Password Rules for root User and globaladmin).
In  Prime Collaboration Provisioning, this password is synched with the  password of postgres admin (to perform backup and restore operations).  The password is then updated in the database and in the /opt/cupm/sep/dfc.properties file. You must log in as a root user to access the dfc.properties file.
Note If  you plan to install both Prime Collaboration Assurance and Prime  Collaboration Provisioning, ensure that you specify the same password  for both applications during installation.
CLI Admin Username—The default username is admin. However, you can specify the username of your choice.
CLI  Admin Password—Specify a password for the SSH CLI admin. This password  is used to log in to the CLI to check the application status and perform  backup and restore (see Password Rules for CLI admin).
The  CLI is supported only through SSH; Telnet is not supported. You can log  in through SSH using port 26 for Assurance and port 22 for Provisioning.
Root user—A superuser who has all privileges in Linux shell.
Root password—Specify a password for the root user (see Password Rules for root User and globaladmin).
Must contain at least one of each: lowercase letter, uppercase letter, number, and special characters.
No character in the password may be repeated more than three times consecutively.
Cannot contain non-ASCII characters, %, +, and &.
Cannot be cisco or ocsic or any variant obtained by changing the capitalization of letters therein, or by substituting 1,!, or | for i, substituting 0 for o, or substituting $ for s.
Cannot be same as the username, and cannot be the username reversed.
Must contain from 8 to 80 characters.
Cannot end with these characters: *, ; or #.
Caution We recommend that you write down the root password, as it cannot be retrieved.
NoteTo  change the root password, you must log in as root user and execute the  "passwd" command, which prompts you for a new password.
If  you are planning to integrate Provisioning and Assurance servers, make  sure that you adhere to the Assurance-specific globaladmin password  rules while setting up / creating the password for globaladmin in  Provisioning.
Must contain atleast six characters.
Must contain at least one of each: lowercase letter, uppercase letter, and number.
Must not be the same as the username itself.
Installation Prompts
We  recommend that you find out the values beforehand for the following  parameters, as you will be required to enter them at the console prompts  when you configure the virtual appliance:
IP address—The IP address of the virtual appliance. If you wish to change the IP address, see
IP default netmask—The default subnet mask for the IP address
IP default gateway—The IP address of the default gateway
Default DNS domain—The default domain name
Primary nameserver—The primary name server. You may add a name server. To configure several name servers, enter y.
Primary NTP server[time.nist.gov]—The primary NTP server. To enter a secondary NTP server, enter y at the next prompt.
Note Prime Collaboration 9.5 supports three NTP servers. To configure a tertiary NTP server, enter y at the next prompt, after you specify a secondary NTP server.
Timezone—The  timestamp that is displayed on the UI is the server time. By default,  the configured timezone is UTC. For a list of supported timezones, see Supported Timezones for Prime Collaboration. You must use the same timezone for Prime Collaboration Assurance and Prime Collaboration Provisioning servers in converged mode.
Username—The CLI admin username. The default is admin. However, you can specify the username of your choice.
Password—The  CLI admin password. This password is used to log in to the CLI to check  the application status and perform backup and restore.
Root password—Specify a password for the root user.
globaladmin—A  superuser of the application who has all privileges, and whose account  used for initial login to the application (UI).
globaladmin password—Specify a password for the globaladmin.
Network deployment mode-Select the network deployment mode you need. Specify E for Enterprise Deployment or M for Managed Service Provider Deployment (E/M).
http://www.cisco.com/en/US/docs/net_mgmt/prime/collaboration/9.5/quick/start/guide/Cisco_Prime_Collaboration_Quick_Start_Guide_9_5.html#wp109430
Cheers!
Rob
- Springsteen
Hi Rob,
Yes you are correct
I wanted to get in to the GUI interface thats the UI with admin as username and password as admin NO GO
even I tried username as globaladmin password the one which I gave in the begining coz I have kept same password for every thing so I canot be wrong at password...
I dont know how I will login now in to the UI
Can you help me to reset it? and get a new username and password for loging in to the UI?
Or do I have to reinstall the complete application again??
Rgds,
Rebecca...
Can we change the password from the PUtty? by logining to the server IP ?
Will it be ssh or telnet? and what is the port number?
375
