Cisco Prime License Manager Instalation
Whats the difference to install Cisco Prime License Manager as standalone or co-resident with one of UC Applications.
Leonardo Santana
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
The difference from ELM is
The difference from ELM is that the application cannot be installed from the CUCM ISO, you need to run separate ISO for PLM and the rest is the same.
Chris
Yes, just like ELM, PLM is
Yes, just like ELM, PLM is installed on every CUCM/UCXN and now CER instance, you pick which one you want to use to manage your licenses as it makes no sense to use multiple.  If you desire to have dedicated PLM you need to install a standalone PLM using one of the CUCM OVAs, the difference between standalone PLM and ELM is that you cannot use the CUCM media to install PLM, and need to download dedicated PLM install media.
Chris
Chris
VIP Purple
Hi Santana, [+5] to Chris.I
Hi Santana,
[+5] to Chris.
I am just capturing the lines from PLM User guide
Deployment model
Cisco Prime License Manager is installed as a standalone product. It may also be automatically installed with
Unified Communications products.
For stand alone installation, the Cisco Prime License Manager ISO is available either from the DVD that was sent to you, or is available at the Software Download Center under Cisco Prime License Manager Virtual Machine Templates.
For co-resident installations, Cisco Prime License Manager is installed automatically as part of the installation of Unified CM, Unity Connection, or both, as well as Cisco Business Edition 6000. You may choose to run Cisco Prime License Manager on one of these servers in a co-resident configuration. Refer to the platform-specific installation document for more information:
• Installing Cisco Unified Communications Manager, Release 10.0(1)
• Installation Guide for Cisco Unity Connection Release 10.0(1)
• Installing Cisco Business Edition 6000, Release 10.0(1)
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/10_0_1/CPLM_BK_U7066CD8_00_user-guide-rel-10-0-1/CPLM_BK_U7066CD8_00_user-guide-rel-10-0-1_chapter_010.html
regds,
aman
So what is the better option?
Co-Resident or StandAlone?
Leonardo Santana
It's up to you, my rule of
It's up to you, my rule of thumb is that if the environment is large i.e. few CUCM servers, CER, UCXN I would build a standalone, if the environment is couple of CUCMs, UCXN I would run it on the CUCM Pub.
Chris
One thing that i do not
One thing that i do not undestand yet, if i install CUCM the PLM will be installed too?
Leonardo Santana
Chris
Thanks again Chris
Thanks again Chris.
Leonardo Santana
1563
