Cisco Prime unified provisioning manager on BE6000
I am planning to install CUCM and Unity Connection on BE6000 soon.  Cisco Prime Unified Provision Manager app is required on the VM?
I don't want to install it if it is not required.
Everyone's tags (1)
1 REPLY
No, just bear in mind that
No, just bear in mind that even if you don't install it, you cannot use those resources left for any other app.
It's always 4 or 8 apps of your choice + provisioning manager. Not because you choose to not install it, will the number of apps change.
java
if this helps, please rate
www.cisco.com/go/pdi
38
