Cisco Publisher Crash
lesterccna
Hi Engineers,
Anybody can give a step by step document on how to restore my CCM publisher,
I got an error before booting up the server
Windows 2000 could not start because the following file is missing or
corrupt:
\WINNT\SYSTEM32\CONFIG\SYSTEMced startup options for Windows 2000, press
F8.
You can attempt to repair this file by starting Windows 2000 Setup using
the original Setup floppy disk or CD-ROM Select 'r' at the first screen
to start repair.
There is a document called a "SAME SERVER RECOVERY" but it did not tells you what to do from the start to the finished.
Can anybody help, Please..
Thank you very much,
virverma
Level 4
Level 4
this error message is an existing defect,
This defect happens on all the servers running MCS OS versions 2000.2.6 SR 2 and below.
Any servers that have 2000.2.6 SR3 and above installed or 2000.2.7 and above installed
will not see this problem.
Try this workaround,
Delete these registry keys:
HKEY_LOCAL_MACHINE\system\ControlSet001\Control\DeviceClasses\{28d78fad-5a12-
11d1-ae5b-0000f803a8c2}
HKEY_LOCAL_MACHINE\system\ControlSet002\Control\DeviceClasses\{28d78fad-5a12-
and
Add these registry values:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Terminal
Server\WinStations\RDP-Tcp\fDisableCpm = 1
Server\WinStations\RDP-Tcp\fDisableLPT = 1
Hi Virverma,
Thanks to your reply,
I couldn't bootup to the windows 2000 server OS, it stuck-up and hang-up in the black screen, please refer to my attachment.
How can i fix this and return to Operational OS.
Thank you very much
DO you have the windows 2000 CD?
